Industry07
  1. Had a problem very similar if not identical, turned out being the coil pack failing under load.
  2. Ok This is what I found on training new keys,, You will need to have 2 coded keys available if you wish to train a new key. ensure you have all keys present during recoding as any key not present will be removed from the memory. Sit is the drivers seat with doors closed Put the first coded key into the ignition & turn to the ACC position. Turn this key to the OFF postition & remove the key. Within 5 seconds put the 2nd coded key into the ignition & turn this key to the ON postition. Turn this key back to the OFF postition and remove the key. The door locks will then cylcle to indicate that the learning mode is active. Within 5 seconds put the new 3rd or new key into the ignition & turn to the ON postition. The door locks will cycle 3 times to indicate the 3rd key has been trained , ensure you wait for the locks to finish cycling before turning the key to the OFF position. Repeat this step for any following keys , The 4th key trained will cycle the locks 4 times, and so on. you can train up to a maximum of 8 keys. your new key should now be coded to your car. Problem is its a new barrel how will my original keys train a new barrel and keys??
  3. Thanks Ralph, So I cant take the chip from my original key and put in new key?
  4. Hi all Turbo heads, Question, can I replace the ignition key barrel only, My 3 yr old son stuck a stick in the ignition and snapped it off and me being filled with rage couldn't find a way to remove it sensibly so I got the drill out and drilled it out, Success, So I thought, Key went in, Car starts, Car shuts down, Oh Crap,,, Cant get key out, I damaged the key entry gate and it catches on the end of the key on the way out, Back to Rage,, LOL I see a lot of people are saying the whole column need to be replaced as the barrel cant be removed, But I found that the ignition can be removed and a replacement can be purchased, I need to know , does the barrel itself need coding along with key or can I just replace the barrel and take the immobilizer chip out of my existing key and put in new key..
  5. I'm very grateful of the knowledge you guys bring and couldn't find this on another forum, I will follow up on Elephantitis location & geographical In site and go see a tuner,
  6. Cool how much and were at? Will also need crossover to intercooler pipe and the two hoses off the crossover to standard BOV, lol atm mine is illegal due to the BOV only venting to atmosphere, Sounds Wicked though,
  7. Yea I know to stay away from generic tunes, I thought just by resetting the ecu it would adjust to the extra airflow, What is a dyno tune to the pocket, Also What do you think of the BOV, good or bad for the car?, I was going to go back to standard but those crossovers are hard to come by,
  8. Also what type of tune, a standard tune up ,,, a Dyno tune ??
  9. anyone know of a tuner in the far south sydney area, (wollongong)
  10. Intercooler is is a Monza Factory replacement,, 16 cores rather than the factory 8, I checked or the piping and fittings, all is sealed and tight, Will check again in the morning though,
  11. https://www.youtube.com/watch?v=240nixARMH8&feature=youtu.be Here is the video,
  12. Ok so the pic your seeing is how the car came to me, pipes on back of crossover are welded shut,
  13. Hi Guys, I am unsure if im doing damage or its the way it was meant to sound, I installed a new inter-cooler a new cold air intake and an earls oil feed line , after a full eight hour shift on the car I decided to take it for a test run, negative terminal had been off for an hour or so, reconnected negative idled for ten min, checked all work carried out to make sure nothing was missed got into the car left the drive and bam more turbo noise then ive ever her in 5 yrs of having the car, I cant take a pic of the bay because its to dark to get a good shot but I have edited an image from the net to show how my BOV differs from standard, Also I will upload a vid if I can,,, or wav I look forward to any knowledgeable opinion,
  14. Is there a way to tell what pack is failing? Or should I just get a complete set,
  15. Will it make a difference if I go genuine or not,,, (coil pack) Running stock,
