Kroozin
Everything posted by Kroozin
  1. T56 w/damaged input shaft + twin plate clutch for 300bux
  2. Emptied out the water can I mean catch can hahahahaha! Oh
  3. Gunna if you had the right parts it would look like the pic that Kosij put up. Can you put the parts in a similar fashion to the above pic then take a pic and upload it? It would be good to see what you got.
  4. Cereal? Are the Fg NA cams same as turbo?
  5. Do you know if there's much in it? Looks pretty damn close only I'm unsure of the section over the diff. can't tell thru the pics
  6. Ah ok so modded Fg exhaust?
  7. Where are you getting the 4" cat back done?
  8. Kroozin
    Ute Exhaust
    What have ya got?
  9. Name: Brendan Car: Bf XR6T Trans: 6 Speed man Power: 400rwkw with 1100nm torque Boost: 17psi Induction: 4" turbo side plaz Intercooler: 1000hp plaz with 2/3" custom hot side and 3" cold side piping Turbo: 6235 50mm ext. gate Valve Springs: Crow cams Exhaust: 4" Dump into twin 2.5" Fuel Sytem: 1000cc Inectors with 1000hp aeromotive Fuel Pump inc. surge + upgraded intank. XCAL3 flash tuned by CMS on eflex
  10. http://youtu.be/J69GVmIpgJ8
  11. Good thing about the fg's is you can always adjust it on the car, bit of a *beep* but it can be done. Probly would put a beez dick of preload on it myself but meh zero is def. safest.
  12. Usually their not too bad. Maybe use some anti-seize when you refit the new stud kit.
  13. Maybe just pull the manifold outta the car and do it on the bench. Just need to get to those bitch bolts for that bracket which you don't need.
  14. Ok One after?
  15. Crank case breather hose. Found that a vl heater hose is the right size and has a neat 90deg bend
  16. Fitted a Expensive Daewoo part :-(
  17. Cruise wknd after next peeps?
  18. Wouldn't mind doin a run to Bathurst via bells line of road Or Another lap around gosford back thru wisemans (love this one) Maybe even a run back down maq pass the way we went last time along the water
  19. Nothing wrong with what you do bud. I'm just a keen mofo
  20. I vote kroozin for cruise control Haven't seen the other blokes around for f*ck knows
  21. Yeah I saw that one (This is a family friendly cruise to which I encourage members to bring there wife, kids, girlfriend, boyfriend, mother, father, brother, sister, uncle, anuty, nan, pop who ever you want.) Some reason I prefer driving at night...anyhoo Work most Saturday days too which is a pita
  22. So when the next cruise lads? Thinking another Saturday night cruise....
