Hi Buddy, currently getting by BA FG'd. Done the full hog with entire dash, body wiring looms, new FG Motor, new FG 6Spd, ABS/DSC. Did you have any need to replace your ABS Wheel sensors? I'm assuming you had the BA Bosch 5.3 module originally, and swapped it out for the BF's ABS unit? I'm unsure if the BF runs a Bosch 5.3 or a Bosch 8.0, but the FG Runs a Bosch 8.1 which I've installed in my BA. The BA wheel speed sensors are apparently incompatible with the FG Bosch 8.1. In the rear, I've managed to install FG speed sensors, but the front ones are too much trouble to mount. FG wheel speed sensors are mounted inside the actual FG wheel hub, while BA/BF run them external on the suspension uprights. Can you tell me what Bosch module version you are running (part number would be great). Do you have traction and ABS?
