thecook
7 Neutral
  1. thecook
    Boost
    @ what rpm do the xr6t start to make boost b series
  2. diagnosis the clutch plate has welded itself to the back of the pressure plate and also to the flywheel. no heat marks on the flywheel. I don't give the car a hard time.
  3. Shed some light boys if you don't mind. New clutch 2 months later slave sh*t it self 1 month later I let it go in ist boom crash bang no clutch but the peddle feels fine. what could it be.
  4. changed the oil with some supa dupa expensive synthetic stuff can't remember the brand just remember the $$$$$.
  5. I had this name problem for a long time and finally fixed it too.
  6. After going thru a lot of top end tyres pirelli michelin bridgestone dunlop they all have issues for the last 3 years I have been running goods year f1 at the front and invos in the rear and cant complain great breaking handling and exceleration.
  7. confort bush is what I put in and only the diff bush thank you I have put supapro bushs I think nearly everwhere and yes have alot more axle tramp than I had before.
  8. mate its suppose to be the best out there supapro
  9. Just wanted to know what would be the cause of your diff bush to give way after 500 ks of normal driving
  10. I am after the foam seat insert for a drivers seat any body changed one and where can I find them.
  11. this wont fit on a six speed shaft unless you drill it bigger.
  12. its not part of the shaft its seperate but it bloody hard to get off.
  13. had mine replaced twice under warranty just go and see them.
  14. thanks for the feedback its just alot of people go by dyno # and as there are so much variances in read outs people are not really getting what they think there getting. and more often than not $$$$ equals kw more you spend the more power youll have and with these huge difference's who to no. only the 1/4 mile track will give you 100% unbias feedback.
  15. After not sure about my dyno readout went and got a second opinion from someone has a reputation for not pulling any punch's and there was a 70 RWKwasps different in my car and it still drives the same as it did from day uno. Has anyone had the same issues?
