LP640
  1. So the wheels turned up the other day and they sent me +25 offset for the fronts instead of +34 Luckily these should still work with some front guard rolling and running 245/30s whilst still remaining legal for overall track increase. Does anyone have any pictures of BA/BFs with 20x8.5 +25 offset on the fronts? Also regarding the 20x10 +40 offset rears, I test fitted them and there is maybe 5-6mm clearance on the inner suspension and arm. I was told that since it is so close I wont be able to run a 285/25 Nitto Invo tyre as the sidewalls stick out further than their listed 285mm tread width.. anybody have experience with this? Thanks in advance!
  2. Will there be any 255/30/20 INVOs coming in the next batch?
  3. 285mm wide and 25% of 285mm is the sidewall which in this case is 71.25mm. Most tyre shops put 275/30/20 on the rear because the sidewall is 82.262mm which gives better shock absorption. HOWEVER doing a 275/30 increases your overall wheel diameter by more than 15mm and in the majority of states that is illegal!! Its good that the tyre store told you about the 285/25 but expect to pay a lot more for the 285/25 over the 275/30.. I think price is the main reason why most people run 275/30s even though its illegal. Stick with the 285s... I know on BA/BF's you need to roll the rear guards to run them... not sure about the FG. Goodluck!
  4. Sent you a PM. Can you get the 255/30/20 92Y Invo's?
  5. What rims did you have and what offset were they?
  6. Yeah I know of that thread. I tried asking my questions there but no luck. They're mainly saying a 245/35 wont fit due to the sidewall height which is 85.598mm. However the 255/30 sidewall height is 76.454mm which is only 3mm taller than a 245/30(73.406mm) so that's why I thought it may fit. Nice! Did you have any issues with the 255s on the front?
  7. I've searched and asked around different forums but have had no luck so I thought is try here. As the title says.. Wheels are 20x8.5 +34 offset. Just wondering if anyone an tell me if they will hit the upper control arm and other inner components? Also regarding the rears... a 285/25/20 should fit fine on a 20x10 rim +40 offset with guard rolling yes? Any info would be greatly appreciated! Thanks!
