Is the clutch standard? If so they can be painful to bleed. On the top left hand side of the gearbox in the start of the belgousing there is a little hole there. If your clutch is stock you will JUST manage to see a bleeder that is extended out from the csc. From memory it's 10mm but may be 8. Make sure you get a catching system on the bleeder as to avoid fluid getting in the belhousing. Falcon clutches are a pain to bleed. After bleeding through with a suction pump. I bleed through properly with a second person: down open, close up etc. After that's done I pump the clutch continuously for about 5 minutes with the lid off and that normally self bleed the remainder. I it's still average. Leave the lid off for a couple hours and try again. Should be good then! If you have Ace clutch your in for a treat. The bleeder comes out of the box in a braided line, so damn easy in comparison The most like cause if the fluid is low. When you depress the pedal it has sucked air from Depletin the resiovouir. Best of luck mate if you have any dramas feel free to PM
