xrsmnt
About xrsmnt
  • Birthday 03/04/1989
  • Interests
    turbo's, Canadian club, women, and star bar.
  1. Happy Birthday xrsmnt!
  2. Happy Birthday xrsmnt!
  3. Happy Birthday xrsmnt!
  4. Happy Birthday xrsmnt!
  5. thanks for the help, engine is fairly tidy, apart from all the extra wiring for the eboost controller.. quick question is $165 for a dyno tune expensive? n if u guys want good tyres just bought hankook's wat a bloody awesome tyrem not even the slightest wheel spin on full boost.
  6. thanks for all the comments, I just bought a bf gt front grill, gonna spray the cooler black. I might buy a pipe that goes from turbo to somewhere that has good air flow and colder than engine heat soaked induction.. or maybe relocate the battery to the factory air box area. quick question if the cat has a specific tune on it, if I remove the battery will it interfere with the tune? coz im not sure if its stock ecu.. is there a way to tell?
  7. Can I be added to the list. Cya there
  8. is relocating the battery to the boot expensive? I was thinking about the heat soaked air intake being a couple of inches from the motor.. might have to get something better.. is a bov a good mod to have or should I leave it on?
  9. na its custom piping, have a look if u like http://www.carsales.com.au/all-cars/private/details.aspx?trecs=25&tsrc=allcarhome&__Ntk=CarAll&PriceFrom=391&__Ntt=turbo&R=10321092&seot=1&silo=1011&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=turbo&__D=turbo&__sid=12E00559115B&Cr=1&__N=1216%201246%201247%201252%201282%204294966463%204294966285%20391%20410%20903&PriceTo=410&__Ntx=mode%20matchallpartial&__Qpb=true&__Nne=15&__Dx=mode%20matchany copy n paste it in the web address. but the flutter is so loud, any way to quieten it?
  10. wats wrong with the pwr cooler?? idk man, the guy I bought it off said it has 1 haha.n thanks for lettin me know, as u can tell im new to this stuff..
  11. yer mate I am.. are you??
  12. hey all, just bought an xr6t as I have wanted 1 for since I seen them n now bought 1. I have the following n the previous owner reckons he had 320rwkw's. MODS; PWR intercooler. reconditioned turbo with upgraded actuator and flap spring in turbo housing. crow valve springs. 60lb injectors. new engine hose pipes and belts. high pressure oil lines for turbo. bosch 440 in tank fuel pump upgrade. 2litre under car surge tank. heavy duty ceramic clutch. E-boost controller hi low boost switch 16 psi or 8 psi. typhoon coil and plugs. tuned for 98 octane. full xforce exhaust from turbo back, high flow cat to twin pipes. blow off valve. short pod filter. will this make 320rwkws with 16 or 8psi? coz its very scary on 16psi.
  13. xr6t looking sexy in my driveway
