KEBAB_DRIFTER
4 Neutral
  1. I suppose if I wanted a sports car I would of bought an XR6? ...... This is a cruiser I just want to be able to dump it on the ground for daily duties and raise it up when I buy a cardigan
  2. Now were talking , but that's the kind of reply im looking for as I dont want to max out the coil over , What sort of height range can we achieve with coil overs eg a 5'' drop?
  3. Cheers Angel Yes cheers , It seems all the fronts seem to go low enough its the rears im thinking about , how does the rear spring height vary over the different brands Your problem?
  4. Hi guys just purchased a G6E Turbo and im chasing a set of coil overs that go really low , ive seen a pic of XYZ coils that seems to be pretty low but pic was taken from above will I have to remove the rear adjusters to get the desired rear height? Can anyone recommend a brand that will go low but retain a softer spring rate eg... 10kg? Yes I understand the logic of why would I want to go that low on a g6 , coming from a skyline that was 50mm off the ground I think ill cope plus airbag sus isn't a bolt in option XYZ , PEDDERS , KSPORT , OZ racing, a mod on here had some COILS he was making , others? Cheers Mick
  5. Bring back the F6 TYPHOON like GT4
