QWK40L
About QWK40L
  • Birthday 31/07/1987
    SYDNEY
  • Interests
    MY XR6 TURBO.
  1. Happy Birthday QWK40L!
  2. Happy Birthday QWK40L!
  3. Happy Birthday QWK40L!
  4. Happy Birthday QWK40L!
  5. Happy Birthday QWK40L!
  6. thanks for the posts guys but have decided to put mahle pistons and howard conrods. will keep you guys posted with the results. should have the car back in 2 weeks.
  7. yeah your right, which means I can up the boost and throws some more timing in it and gain more power.
  8. What power will I make with a built bottom end and with the stuff ive got at the moment.
  9. at the moment ive got 344rwkw on a standard bottom end, MODIFICATIPONS: Process west plenum Plazmaman 1000hp intercooler Plazmaman under battery pipe plazmaman hot side piping Nizpro injectors Turbosmart blow off supersonic Walbro fuel pump Plazmaman surge tank Xforce exhaust 4inch dump into 3.5" single exhaust with quad tips Atomic valve springs Brand new lifters 14psi boost modified standar wastegate dont want to spend more the 7k
  10. hey Guys, How much are you guys paying for a bottom end upgrade like pistons, conrods, im in the process of strengthening the bottom end of my BA XR6 Turbo. I want to throw in mahle pistons, howard conrods and whatever else is needed.
  11. Hey Arronm, do u use a spacer at all.
  12. hi Guys, Grinded 7ml off the thread, took of the 5ml spacer off but the rim scarpes on the inside know, can some tell me if they use a spacer for 20x10 on there sedans, it just touches I reckon it needs about a 2ml spacer and it will be fine.
  13. ozzy tyres put me a 5ml spacer but it helped abit, the caps had to be shaved a bit on the inside so they go on. I thought there might be a another way around it.
  14. hey, Ill try upload a photo some time today as im at work at the moment thanks
