Kybus
1 Neutral
  1. Can u just replace HIM (plug n play) Do you need to reprogram it like the ICC ? Cheers Kybus.
  2. Guys, even though my AC fan control is on low, it runs at high speed at times and dose not turn of when either ignition switched off or even OFF on ICC. I need to disconnect battery for it to stop. I’m asking for help, what could be the issue / solution? cheers Kybus.
  3. Kybus
    BCM fault
    Im going to Peter Warren tomorrow to get there opinion. cheers.
  4. Kybus
    BCM fault
    I’m after a ford auto specialist to explain my best options. cheers.
  5. Kybus
    BCM fault
    Hey guys, I have been informed by my auto electrician that I have a BCM fault and Climate control module fault. would anyone be able to recommend a service in Sydney that would be able to help me? Regards Kybus.
  6. So just disconnecting the battery for a couple hours might reset it?
  7. Car not started for 4 weeks,(battery on 6months old) car started for no issues for a week. did not start, NRMA checked and recharged….. battery good. now AC cool won’t work, and Dan control stays on max, even when reduced to min. regards Kybus.
  8. Keith, thank you mate, this could solve the issue I've had for over 12 months(a high static noise) even when radio is off. No one knew how to fix it. no consistency with the noise though. I have disconnected the amp, only time will tell. Cheers Kybus
  9. Randomly getting static / scratching noise through speakers no idea why this is happening, even when Audio is off. I have a video I would gladly SMS if your happy to listen to video to get an understanding of noise. regards Jay.
  10. seriously if it was either of the above , wouldnt the car be over heating ? Which it isnt. im guessing it might be electric(switch) or something What is your thoughts ? Kybus
  11. thank yoiu , I have a friend asking the question today at sinclare ford. hopefully it is just a computer thing(switch)
  12. do I have to replace it, or can it be fixed ?
  13. Guys, I aint getting any heat from Air con(set @ 28°). How can I fix it ? Kybus
