Relentless xr6t
About Relentless xr6t
  • Birthday 28/12/1990
    liverpool
  1. Happy Birthday Relentless xr6t!
  2. Happy Birthday Relentless xr6t!
  3. dont they run a bigger housing with a bigger bearing bigger axles aswell I heard something like that a while ago
  4. hey I am currently trying to sell my ford ba mk11 xr6t sedan diff assembly it has 20 000km on it almost brand new it also comes with 1 standard ford brake caliper 3.73 lsd $1000 pick up only from sydneys west
  5. some info if anyone was to do a conversion firstly pcm would have to be changed to a turbo t56 parameters will have to be reset you will need a t56 manual pcm loom for the reverse lockout and most likely a custom made shaft and definetly get a good after market clutch xr6t pedal box will be needed hope this helps
  6. are you still in need for a t5 or t56 I would recommend staying with the t5 as the t56 will require the pcm wiring loom to be modified and maybe a tailshaft change I have a t5 post me if you are intrested??
  7. mate that was great info yeh im going to take some mesurements and see how things work out +1 for detail mate respect!!
  8. hey im intrested in upgrading my brakes to brembo 6 piston front 4 piston rear I have 18 inch rims and from what I hear they will fit I am just curious if its just a simple bolt on or does the master cylinder or something like that needs to be changed 4 this to work any tips will be surely appreciated
  9. my car went to peter warren warwick farm sydney and sam the foreman worked on my car and done a awesome job he was very helpful and done the job in 45 minutes charged me 137 dollars I could not of asked for a better ford mechanic to do a parameter reset and he also let me no the exhaust was rubbing and that my gromet where I ran my gauges through had fell out that why there was so much road noise cant thank the boys at ford peter warren enough for the great work.
  10. someone told me that the fuse box may have been diffrent have you changed that by any chance I think it was intune motorsport that mentioned that to me
  11. I am running a stock t56 manual xr6t computer my auto elec mate got it started with a program called chase he is a wiz but the car is still going to ford tomomorow for a parameter reset I hope a sh*t *beep* ford aprentice doesnt touch it being a mechanic my self I no how sh*t aprentices are im hoping for it to be done quickly as I am out of pocket now hahahaha
  12. hey I have completed my turbo conversion and need to take my car to ford for the parameter reset tomorow just wondering since ive put this set of mods on can I drive it around safely on a ford 6 pound tune mods are: growler cold air induction,walbro fuel pump,turbo flapper valve ported, new actuator 12psi 4 inch dump pipe into 5 inch cat to twin 2 1/2 inch 2 mufflers all exforce quiet system. can you control the 12 psi actuator to open the wastegate at 6 psi to I get a custom tune. any information would definetly help please!
  13. a xr6t is almost impossible to bypass unless someone roles you for your keys
  14. ss inductions pod is sh*t they never fit right look sh*t from the inside I launched mine out the window and fitted a pole postion 1 I got from intune motorsport 1 of the best gauge pods out to date
  15. hey bentles I got a few questions about my turbo conversion that I am on the last steps
    you take it to ford to get the pcm to talk to the body module right but did u have any problems of your speedo not working dash security code and theft mode my car is going to ford on friday I have done a whole motor change and gearbox change pcm and harness change this is in a ute any info would ...
