shanerobertson
3 Neutral
About shanerobertson
  • Birthday 30/01/1974
    Geraldton W.A.
  1. So no dramas with these then? Model : Avant Garde M310 Size : 20x9 (F) & 20x10 ® Bolt pattern : 5x114.3 Offset : 30mm (F) & 40mm ® Hub Bore : 70.6mm Lip Size : N/A Finish : Matte Black Condition : Brand New in Box Quantity : Set of 4 Wheels Center Cap : Include Fitment : FORD MUSTANT 2005 - 2012
  2. Happy Birthday shanerobertson!
  3. Finding it hard to find the right black staggered 20" rims. Ideas or photo's would help.
  4. What diameter rims are you looking at? 18" 19" or 20" ? For the BA/BF it seems that normal is 8" for front width and 245/30's (not 35) are all you can do for the front without hitting ball joints. Any wider and your pumping guards and rolling lip and camber adjustment. Rear is up for debate depending on diameter and offset. Normal is 9.5" max and 265/30, maybe 275/30 without modifying. Any wider and your pumping guards and rolling lip and camber adjustment. So how wide is wide enough? Heaps of guys on this site have 19" for BA/BF's, a few with 10" or even 10.5" ( tocchi ).Definately will get some good advice on here. Hope this helps.
  5. On this site. Found a couple on off topic threads. One was in interior exterior. Although one mentioned SL or SSL. Suspension? I'll look again after work. And I'm just curious about Worm' B tyre sizes as they look stretched so no rubbing.
  6. Hi, Should ask WORM what rubber did you fit to your rims, KOYA INOX R1 20x10 (+38) and 20x8.5 (+35), that I saw on another thread. Any mods to get them to fit?
  7. I'm thinking for a FG Sedan a 20" x 9" front with 265/30/20 +30 offset then 20" x 10" rear with 285/30/20 +40 offset. From a bit of research this should fit without any modification. Now to find all black rims to suit the my black turbo. Looking forward to XXXRTURBO's photo's to show what he bought and offsets used to see if I'm close to being right . Looking for photo's of other cars with 20"s on, and sizes plus offsets if available.
  8. I'm thinking that it's safer to not be too silly on the front now, maybe just 255. More than that seems to be to much trouble although I'd like more. As rynof6 said I'd be better off with better rubber rather than width. Tocchi on the forum has run 10" on the front but I can't find more than that. How did it fit? Plus BF front ends have a different suspension setup to the FG. And 20" reads different to 18". Do you cop alot of excessive inside wear with the camber? Or get the tyres rotated regularly? And what do you run with on the rear if you had 275 fronts? Maybe road legal semi slicks. It doesn't rain much here.
  9. Running Goodyear F1 assemetrical 245/40/18 on the stock rims and they are so much better than the Dunlop's. But the prices in 20's with these width my prove to be a budget buster. So ideas are welcomed.
  10. Doesn't need to be so wide if they don't fit. The main problem is wheelspin on low throttle in 2nd and sometimes 3rd with 245's and ZF box so the rear is most important. So if 285's fit without mods and if Prodrive Performance parts come on line with mod Control Blades to allow 295 or 305 I'll smile. Thanks for the links, checking them out now.
  11. Has anyone had expirence with any of these aftermarket kits? Did they fit well? No dramas? Or did they line up badly, not clip on etc. ? Advice is welcomed. Thank you.
  12. Have gone with the Growler, and stopped. Now looking at 20"s again mainly for looks. Plotting 20x9 255/30/20 +36 front and 20x10 285/30/20 +40 rear. Big fan of Goodyear F1 assemetrical on my 18"s now unless there is some tips out there.
  13. Oh and how has Tocchi fitted such extreme rubber on his cars?
  14. Do you think 255 or 265 with a 30 profile?
  15. Rynof6 seems to have the right idea about offsets. But as offset ratios change with the rim width getting the right information is vital to getting the best fit. I'll guess that a good tyre fitter could measure the offsets to get the fit right on. I hope. Might need to do offline research then post it when I can get figures. I'm still keen on finding a 20" version of the standard XR6T rims, like the company that made the 20" versions of the Dark Argents, including the different widths. Has that stock but somethings different look. These would do, once you change the centre cap, but only come in 9" for the Magnum and 9.5" and 10.5" for the BMW Apec E70's. No idea of offsets on them though. But if those fit....
