blueboost
Everything posted by blueboost
  1. auto or man
  2. it a fine edge, does not alway's happen straight away, good effort Bog's anyway. David
  3. yeh I tuned it, and put the blower on,still has my tune in it, but he has done some performance mods himself since as well, so credit goes to him. I know it is still the standed motor. David
  4. I will get more info when I get hold of him, I was not there he rang me after, and I think he might have to get a cage now, so I don't know his plans yet. David
  5. is yours 15psi at peak power? David
  6. what was the result Bogan? david
  7. Well done guy's!!!! sounds like you should be racing each other. David
  8. Brett up in townsville ran his PB today, in townsville, 10.7@ 128mph and ran a 1.57 60ft, that's a good launch for an old bloke. the car is a Ken Bell BF GT 6speed auto. David
  9. I think Brian needs to go for a drive up to Willow bank, while the track is as sticky as it is(after the winter Nats) his is a jet. David
  10. Good on ya, Good luck, David
  11. you might be able to do it by the numbers, but im not sure, but if it is 3.7, it will be out of a 6speed man,xr6t, xr8, GT, and will be limited slip, will not fit in a normal xt cradle,ive been told but have not seen for myself. David
  12. has not been on a dyno, she was a street tune, but it will have between 295-305allwkws David
  13. no, atomic bottom end, most of the top off me old one.
  14. the easiest way to check, is turn the pinion 3.7 times, and the cv should turn once. David
  15. no I had a bit to much work on, the motor is in, just have to put the box in and get a few miles on it. David
  16. your spending money on advertising, not on improvements. I can't put it better then that, not worth 1 kw. David
  17. my BA ,car had two magic cats in place and pump fuel, but sounds like Brians was the closest BF with every thing in place, 11.01, that is close, should have went to the toilet first, just to get rid of that excess weight, might have made the difference. come on Bogan get out there and get that ten it was freezing up here last night must, must have been colder down there. crack a 1.59 60ft, and she will do it easy. David
  18. I remamber you saying that, you don't get much closer do you, I think Bogan and you Brian should get together and sought out a start for your car. David
  19. if I had seen that sump and timing cover before I had put my motor together, I would have got it done, that looks sweet. David
  20. Well done,that's a good drive, the BA times are in sight now, BA's have ran tens on pump fuel street trim, (MT's) but has a 6speed done it in a BF? David
  21. what is your best 60ft?
  22. if yours is spinning on the line, it is allready done to it, the standed tune does not let you stall over 2200rpm,(around this, it is actualy torque based)
  23. I thought you were spinning off the line?
