Articles
Media Demo
Everything posted by benmwhite
Preston Autos do great work - they did the 4speed on my ute which was running 330rwkw at the time. Nice fellas to deal with too.
"Well fronts are actually 3mm larger dia but 4mm thinner." - did you mean thicker Falchoon? The PBR kit, the fronts (325mmx32mm) are larger in diameter by 3mm and thicker by 4mm than the stock (which on a BF are 322mm x 28mm) in addition, the PBR performance kit brakes are slotted and vented and have SS braided lines. The stock rears (on a BF are 328mm x 26mm "pillar vented") are better than the current spec PBR performance kit (303mm x 16mm - solid) Check with BCR01 though - When I spoke with him recently about this, he told me that the PBR performance kit is about to be upgraded to vented rear rotors. Adam also mentioned the "M-series" PBRs that he has been running - 6pistons - sounded awesome... (From memory, performance ford mag giving away a set somewhere???) In any upgrade, I would recommend going for braided lines - as pedal feel was significantly improved IMHO Out of interest, will the turbo territory 340mm x 32mm front rotors & calipers fit under 17" rims as EZ2CME was asking?
The PBR performance kit will fit I ran one under my 17s on my first XR6T ute - PM BCR01 in North Qld as he can supply at a good price.
Looks the goods - a touch of styling influence by Zorro?
apparently all for do is pull them to bits - put some A-grade eucalyptus oil on it to clean the gunk off it and put them back together!!!
GM 6L80E 1st 4.02 2nd 2.36 3rd 1.53 4th 1.15 5th 0.85 6th 0.67 Rev 3.06 Torque capacity (have read 750nm)?? is this right??? ZF 6HP26 1st 4.17 2nd 2.34 3rd 1.52 4th 1.14 5th 0.87 6th 0.69 Rev 3.4 Torque capacity ( 450nm and 600nm )
...plead religious reasons.... ...your religion? Turbology....
http://www.carpoint.com.au/used-car/FORD/F...csn1341028.aspx
Try these: http://www.carcarrying.com.au http://www.movingcars.com.au http://www.airroaddirect.com.au
Best I ever got out of one of those was 165kph - ....downhill with a tailwind...
I'm not a real fan of car bras - apart from looking a bit ordinary do they rub the paintwork when using them?
Personally I'm not a fan of mixing coolants - I'd agree with Paranormal - in topping it up with water - I use distilled just to be on the safe side. The only problem with continually doing this is that it dilutes the coolant - reducing the effective % of glycol in the mix - Most good mechanics have a refractometer which will indicate the % glycol in your cooling system - if it gets low - (I use 25% as a benchmark), its probably not a bad time to flush and replace.
yup - that's prolly what I meant by a bit cocky!!!
True - although not sure that's what this thread is all about - I dont imagine these guys spend 200k+ on a sports car then drive ( read strut ) around looking for a run to test it out without being a little bit cocky... I guess if they get "flogged" by a cheaper car its a bit of a leveller (a long way from being 'embarrassed or ashamed' ) - as it would be for us in our 'T's getting left behind by the 180b if we were asking for it!! At the end of the day its all about the common denominator - performance cars - regardless of whether it is the driver of the Porsche, a modded 'T' or a quick 180b, there is obviously a healthy interest, understanding and respect for a motor vehicle that performs.
Engine Bore & Stroke: 96.0mm x 78.0mm Displacement: 3387cc Compression Ratio: 11.0:1 Fuel System: Multi-point Fuel Injection Engine Block: 3.4 Litre, V6 Maximum Power: 217kW@6250rpm Max Torque: 340Nm@4700rpm Cylinders: 6 Valves: 4 per cylinder Transmission: 6 speed manual yup - sounds about right --- ...I had a run with a new 911 turbo last month Engine Displacement: 3600cc Compression Ratio: 9.0:1 Engine Block: 3.6 Litre, V6 Maximum Power: 353kW Max Torque: 620Nm Cylinders: 6 Valves: 4 per cylinder Transmission: 6 speed manual I waved as I went past - I got the feeling he didnt enjoy having his $327k mid-life-crisis-mobile being whipped by some young punk in a seemingly stock $45k ute
Yup - that's a carryboy - you can see the oval logo at the back... Saw a "Mach 3" hardlid on a ute in a magazine recently - anyone heard of these?? Couldnt find anything on the web about them...
Goldie is your man!
Bosch V Siemens Injectors
benmwhite replied to benmwhite's topic in Fuel System & Induction Workshop
..think we have something in common... PM Sent... -
Having researched some of the threads here, it looks as though the siemens injectors might be better value for money than the Bosch 968s (610cc v 440cc for roughly the same price). But do either of these two injectors make a tuners like more difficult? If a tuner is more used to using 968s but they have to work with the Siemens, will the tuner have to spend a stack more time tuning on the dyno given it may not be a combination they are used to??
Give us some more detail mate if you would not mind, Size price etc. May as well look at all options. Scotty ← Scotty - RRP is $1699, but you can pick them up for $1300ish A handy 'home theatre in a box' setup if you arent going the whole hog or, like me, are putting in a second system. Picture/Display Aspect ratio : 4:3, 16:9 D/A converter : 12 bit, 108 MHz Picture enhancement : High Def (720p, 1080i), Video upscaling, Video upsampling Sound D/A converter : 24 bit, 192 kHz Frequency response : 30-50000 Hz Signal to noise ratio : >95 dB Sound System : Stereo, Dolby Digital EX, DTS, Dolby Prologic II, Dolby Digital Sound Enhancement : Class "D" Digital Amplifier, Treble and Bass Control, Night Mode Output power (RMS) : 3x125W (Front L/R/ Front Centre) + 2x85W (Rear L/R) + 105W (Rear Centre) + 150W (Subwoofer) Total Sound Power (RMS) : 800 W Equalizer settings : Action, Classic, Concert, Digital, Drama, Jazz, Rock, Sci-Fi Video Playback Playback Media : DVD-Video, DVD+RW, DVD+R, DVD-RW (Video mode), DVD-R, Video CD/SVCD, CD-R/CD-RW, Super Audio CD Compression formats : MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0 Video disc playback system : NTSC, PAL Audio Playback Playback Media : CD, MP3-CD, SACD Multichannel, SACD Stereo, CD-R, CD-RW Compression format : MP3, PCM, WMA MP3 bit rates : 32-256 kbps and VBR Disc Playback Modes : CD Text display, Fast Forward/Backward, Next/Previous Album Search, Next/Previous Track Search, Repeat one/album/all, Shuffle Play Still Picture Playback Playback Media : Picture CD Picture compression format : JPEG Picture enhancement : Slideshow with MP3 playback Tuner/Reception/Transmission Tuner Bands : FM Stereo, AM Number of Preset Channels : 20 Auto digital tuning : yes Auto store : yes Connectivity Other connections : AUX in, Analog audio Left/Right in, ComponentVideo out Progressive, Composite video (CVBS) out, Digital coaxial in, Easy-Fit speaker connectors, FM Antenna, HDMI out, S-Video out, TV in (audio, cinch) Convenience Child Protection : Parental Control On-Screen Display languages : English, Brazilian Portuguese, Spanish, Traditional Chinese, Malay, Canadian French Remote Control : Multi-functional Power Power supply : 110-240V, 50/60 Hz Standby power consumption : < 1 W Power consumption : 165 W Loudspeakers Satellite Speaker : 2 way, Magnetically shielded front, 4 Floor standing pillars, Wireless rear speakers Satellite speaker freq range : 120-50000 Hz Satellite speaker impedance : 6 ohm Satellite speaker drivers : 4" ribbon tweeter, 2x 3" full range woofer Center Speaker : 2 way Center speaker drivers : 2x 3" full range woofers, 4" ribbon tweeter Center freq range : 120-50000 Hz Center speaker impedance : 6 ohm Subwoofer driver : 6.5" high efficiency woofer Subwoofer freq range : 30-120 Hz Subwoofer impedance : 4 ohm Accessories Included Accessories : User Manual, Quick start guide, Remote Control, 1x center speaker, 1x subwoofer, 2x front satellite speakers, 3x rear satellite speakers, Interconnect cable, FM antenna, Screws for wall mounting x2, World Wide Warranty leaflet Dimensions Set Width : 273 mm Set Height : 284 mm Set Depth : 144 mm Set weight : 2.8 kg Center Speaker Width : 497 mm Center Speaker Height : 139 mm Center Speaker Depth : 32 mm Center Speaker Weight : 1.5 kg Rear Speaker Depth : 32 mm Rear Speaker Height : 139 mm Rear Speaker Weight : 1.5 kg Rear Speaker Width : 497 mm Surround Speaker Width : 106 mm Surround Speaker Height : 497 mm Surround Speaker Depth : 32 mm Surround speaker Weight : 1.25 kg Subwoofer Width : 300 mm Subwoofer Height : 399 mm Subwoofer Depth : 300 mm Subwoofer Weight : 12 kg Stand width : 240 mm Stand height : 830 mm Stand depth : 240 mm Stand weight : 4.5 kg Weight incl. Packaging : 47.5 kg
I just ordered one of these... As our lounge didnt have a lot of space for a massive receiver and player... ( I have a Denon setup in our theatre and just wanted something smaller for the lounge ) The wireless rear speakers will be next to useless as I pre-wired both rooms in our house for 5.1 when we were building. But it has HDMI out and upscaling so will plug into the Samsung Rseries LCD tv we have on the way.... Will let you know how it all goes when it comes in at the end of the month.
Are you sure your dad didnt get it edited and youre running in valet mode???!!!
Anyone seen the latest wheels mag? - 2008 Falcon pics etc? Wheels reveals: 2008 Ford Falcon Exclusive pictures and details expose Ford’s plans for next year's all-important new large car, codenamed Orion. Australia’s leading new car magazine, Wheels has lifted the lid on Ford’s make-or-break next Falcon, the Orion. Wheels’ March issue, on sale this Wednesday (February 28), exposes the Falcon’s dramatic new look and gives exclusive details of the car Ford Australia hopes will reignite both plummeting Falcon sales and the depressed local large car market. Highlights of Wheels’ authoritative take on the car codenamed Orion include: . Detailed pictures of what the new Falcon will look like, including its major styling cues and their links to other cars in Ford’s local and global range; . How the XR performance versions will differ from fleet and family Falcons; . How Ford will beat the rear seat entry problems that have plagued the Falcon since AU; and, . Engineering highlights – including full details of the new Falcon’s suspension, steering, transmissions, engines and new, tougher front end.
