Bellato
    2
Everything posted by Bellato
  1. Good mods: Billet wheel gt3576 and external gate PW Surge Regretful mods: Rapid cooler (should have bought PW stage 1) Rear muffler delete Hurricane dump and cat (should have gone full exhaust) First tuner Sound system Rims (should have stuck with stockies) Springs and shocks (should have gone coilovers for better handling) Camber bushes in the rear (should have bought camber arms) RDA rotors and remsa pads (Should have got brembo's and pbr) A lot of things to change and fix over the next 5-10 years and I will get there, but other financial priorities have arisen
  2. How aggressive? 20psi at 2500-2600? I'm going to give some invo's a try next and see how they go, if they hold on well then time for a more aggressive tune to make the most of the turbo lol
  3. Yea my tune is brought on quite sedately to try and get traction and 2nd gear roll on from 60+ its generally okay, but anything less and it just fry's them. I didn't even get a 'ram boost in' tune, would hate to see what 18psi at 2700-2800 would do for traction lol
  4. Bellato
    In The Club
    What tyres you using to get it to hook up? I've only driven mine at night with 350 on 98 and 1st is completely useless but 2nd is sliding around too (zero degrees at night though). That's on 275 nexen n'fera's
  5. So a few of these gtx3576 making over 400rwkw on e85 with quick spool. Really makes you wonder why everyone jumps to the conclusion that the gtx3582 is the go to turbo. I'm more than happy with my gtx3576 equivalent (only at 350 on 98), biggest problem is trying to launch the thing, just wants to fry 1st and 2nd
  6. Seen plenty of street driven and setup falcons go 10's. If you're going full drag car I wouldn't want anything slower than an 8
  7. Bellato
    High Idle
    Take it back to your tuner and tell them to try again..
  8. I have the walbro 460 in my surge and had up around 90-100psi and so had to get a reg. Even though yours is as a lift pump in the tank I would imagine fuel pressure would still be quite high
  9. I have a red rocket cover too, but it's designed to keep all the 'oil' in
  10. A bit of both. I found it split a couple times pulling off but nothing major, a bit of heat helped it stay together rather than tear. But the main problem was the glue under neath potentially sticking to the paint and/or peeling paint up with it where there was stone chips and stuff. Now of this happened. My front bar and bonnet has a million stone chips and the paint was fine. My car has always been garaged so hard to say the effects of leaving it outside but I would say it wouldn't be great. With this cheaper stuff I dunno if I would go longer than 6 months if the car lives outside just to be sure, it could go longer but you run that risk. If I were to do it again and knowing my car is protected from direct sunlight pretty much 24/7 I wouldn't heistate leaving it on for 18months or more
  11. Hey mate top graph with the 348.8 is the new turbo Oh n just so everyone knows the wrap actually isn't on the car anymore. I was advised on the side of caution being cheap vinyl to take it off after 9 months. Paint underneath was immaculate so just proves the 3m and avery stuff isnt always the only good option
  12. Yea gtx3582 is the go to make good power but wanted to limit myself to 400 in the future and no point having the extra lag You shouldn't be having that much of an issue if the port job was a good one because plenty seem to control up to 20psi no problems. However, if it needs to be redone then $$ wise you might as well go external setup It's not ridiculously loud but yea running 18psi+ it will definitely be loud lol. The way the piping works I'm just going (to get someone) to weld a pipe onto the dump just before the flange at the cat with a v band on the end, then put a vband on the end of the screamer then bend a section to go inbetween. That way just 2 v band clamps to put it in and out, and just put like a blocking plate on the dump pipe side when you want a screamer Nah didn't install the fuel reg but under the impression it's not that hard. Nope factory boost solenoid. Just run the vacuum line that normally goes to the actuator to the bottom port of the external gate and vent the top port to atmosphere. I did have to buy a larger vacuum line to reach the gate though
  13. It's a standard housing and I believe the housing may be machined to fit the wheel, not 100% on that though. Yea mate $2150, bolt on ready to go. I sold my factory turbo complete for $450 though so $1700 out of pocket (plus tune). Yep screamer tucks under the dump pipe and clears good. I bent the lower heat shield off the engine mount right down so it kind of covered the pipe. Compared to buying a gtx3576 it would be about $1380 for the turbo with no rear, then use your rear to get port and flap (add $850), plus a couple of joiner and boost nipple. Probably be $2400 or so, but then would only have the front and core of the old turbo to sell so $200-$300 for it. So worked out probably $400ish cheaper overall and for some people they would just go the gtx, but the guy who makes these believes they are better than the wheel in the gtx so I'm hoping when we lean on it in the future we will know its true potential
  14. Yea 350 is perfect for 2nd gear roll on, 1st you really need to use your brain with your right foot, can't just mash the peddle. I've got some 285 invo's im going to try squeeze on the rear so that'll help with traction. Might attend powercruise early next year if funds allow and see if all holds up to some abuse Not sure what you mean by how does the turbo work but basically its an fg gt3576 with a different compressor wheel on the front. It's billet, larger and has longer tips than the factory wheel. The power level was kept to where I asked, I asked for 16-17psi, 350rwkw and quick street car, all of which was delivered. With valve springs and catback and another pound or 2 of boost no reason why it won't see 370-380rwkw on 98, especially on a colder day. One of these turbos went 370 on 18psi on 98 on another car and that car is about to get an e85 tune so I guarantee it will see over 400. You can see in my 2 tunes that it comes on full boost 200-300rpm slower than the factory turbo but boost was brought in more linearly, before because we couldn't hold boost I just got joe to jam it in early to make early torque Yep videos will come, have only had it back a week and driven it twice because I drive my sh*tbox during the week lol. I'll try get some videos on saturday night handing out some chops Had major boost control issues with the factory setup and was going to go port and flap mod which was going to be about $850 (port and flap, actuator, remove and instal turbo). I thought about having a go myself but thought if I get the preload on the actuator wrong it's going to cost me anyway. Then saw these external gate setups for $895 and there wasn't really many things that could go wrong in installing it myself so saved on labour with it. All up ended up $100 out of pocket more for the external gate and I love the sound of screamers so thought I'd go that route.
  15. By now I figure it was about time for a retune so I took the car up to Sydney to see Joe and the boys at CMS and they ran it up with a base run only making 263rwkw (with about 20 degree higher ambient temps so should have made more not less) and running 11 afr’s, far from impressed as you could imagine. Joe had a bit of a play with the tune and managed to pick up 15rwkw and 150nm of torque with just the tune. Car was much better to drive and had all the everyday characteristics of a good cold start and nice idle that I wanted from the start. Unfortunately for me, still no 300rwkw. Joe put it down to the exhaust flowing too will and actuator just not doing its job holding boost. So back to the drawing board to save some $$ and work out where to take the car. A few months passed before I decided to get some more work done and try crack that elusive 300rwkw mark. After a bit of research I decided on a gtx3576 as this would make the 350rwkw on 98 that I wanted and avoid me having to do a gearbox build in the near future. I found one with 3000kms, ported rear and actuator for $1200 so bought it but was well and truly scammed but luckily enough paypal refunded me. Once I got the money back I ended up buying a billet wheeled gt3576 from xr6turbo developments for about $1250 and also one of their external gate and screamer setups for $900. I had a crack at this myself and it took about 2.5hrs on my own to remove, except I had to take the turbo and manifold in to get the 4 nuts taken off as I didn’t have the tools to get them off without making a mess. Getting everything back together took me about a day because there was a lot of messing around trying to get the gate to line up properly and then plumb everything up correctly. She was finally back together, so gave her a service and away she went to CMS for a retune. New tune managed 349rwkw on 16-17psi and holding it all the way to red line. Initially I expected the kw increase to feel like more, but after driving it for a week or so it’s definitely a step up. I previously use to launch hard in 1st, then once it spun at the top of 1st change. Now 1st is pretty useless unless you want to start a powerskid and have to start in 2nd or shift to 2nd basically straight away. Done a few limiter taps trying to learn the right time to shift. Don’t have any time to go to the drags but will get there eventually and hopefully go somewhere around 11.5-11.7. For now I’m happy just handing out chops on Friday nights At the moment the plans for the future are full exhaust, valve springs, tailshaft and retune on 98 and also an e85 tune, but having just finished 5.5 years of uni I’m going on a well deserved 3 month holiday to Europe and then plan to buy a house as soon as I can so the car will be on hold for any major mods. Thanks for reading
  16. This is going to be a bit of a read but for those who can’t be bothered here’s a simplified version: FG XR6T ZF CMS Tuned Hurricane m/s dump and 100 cell cat, rear muffler delete Rapid Cooler and turbo side ID 1000’s PW Surge with single 460 and FPR 1200 XR6Turbo Developments Billet Wheeled GT3576 Turbosmart 45mm external gate 349rwkw at 16-17psi on 98. So back in 2012 I was in the market for a BFII turbo when I came across a 2008 FG XR6T at pickles in Melbourne with 78,000kms for $20k so immediately got a friend to check it out and it was bought. First impression was incredible how quick it was compared to my BA NA First mod was to put my plastidipped 19” Advanti Fusions on and I liked it because the matte black was just starting to come on trend but this would be changed soon enough. First issue was a horrible knock in the rear end that could not be found. All the basic things like spare wheel and the like were checked and nothing came up. Had a couple shops check it out and firstly changed the control blade bushes to Nolathane. This did nothing for the knock but helped with axle tramp that I was getting. Next suggestions were shocks so I thought perfect opportunity to lower the car. Did some research and ended up with King SSSL fronts and SSSSL rear springs, Monroe GT Shocks, Superpro shortened bump stops, Superpro front upper control arm brackets with shims and rear upper inner control arm camber bushes. I think this all came in at about $1100 delivered. So went through the process and found that the upper inner bush on the left rear could not be accessed without dropping the cradle so thought might aswell get some superpro comfort diff bushes and get them installed while I was going. Bushes were $250 delivered and a local ford dealer installed them for $380. So got all that in but knock was still there. Also had trouble with the ‘camber brackets’ for the front with them not actually being able to correct any more camber than the factory brackets fully shimmed. In the mean time a member had a set of vertini magics come up for sale. 20x8.5+42 and 20x10+38 with 6 tyres all up and set me back $2000. Went to put them on the car and surely enough because I had corrected rear camber they fouled on the guards so went down the road and got the rear guards rolled and pumped ($120 for the pair). Now sitting pretty but that knock was still there. I finally got advice from luke/jesus/bionic (not sure if he’s still around) and he suggested upper outer control arm bushes. Got a set that included upper outer, lower outer and outer toe arm bushes for $90. With the help of my old man made up a contraption with threaded rods, some nuts and sockets and managed to swap all the bushes without taking the arms off the car and finally the knock was gone! I decided to give the car a bit of a note and deleted the rear muffler for straight pipe and twin tips. Not a bad sound considering the cost but quite loud (which I don’t mind being only young). $100 total to do this. Some time amongst all this got a cash job on a buff and polish. I washed the car, clayed it, then washed it again and prepped it to save some $$. For $100 it turned out alright. Before and after pics below. After Next on the list was performance. After a lot of research and trying to find the best and cheapest (have learnt my lesson about doing things cheaply now) way to achieve my goals of 300rwkw I ended up with the following list of parts: ID1000’s - $690 PW Surge and single 460 Pump - $1400ish Rapid V2 cooler kit and turbo side - $1700 Hurricane dump and generic 100cell cat - $800 installed 2nd hand x3 - $400 After waiting about 6 weeks and a lot of messages and calls I finally received the rapid cooler kit, everything else was good. I installed this myself only to find a heap of work was required and a heap of parts needed that weren’t supplied in the kit. Eventually got on, took it to the exhaust shop for dump and cat then to the tuners to install injectors and surge then tune the car. Before tune I also installed an external trans cooler ($250), flushed engine oil, coolant, diff oil and gearbox oil. First choice of tuner was Gentech in Canberra after a lot of deliberation on who to use. Had a heap of troubles with the car spluttering and stalling at idle. First it was a dead fuel pump that was replaced under warranty then it hung around. After a bit of research (because my tuner couldn’t figure it out) I suggested throwing a fuel pressure gauge on as I was on the factory reg and fuel pressure was up around 100psi and causing havoc. Spoke to Kev at PW and he sorted us out with a stage 1 fitting kit (FPR1200 fuel reg) at cost price because it was only recommended (not required) on their site. Got that hooked up and car running okay. Only ended up with 295rwkw at 14psi tapering to 10psi. Was far from happy I was expecting over 300rwkw and the car had average economy and stalled occasionally. After going back for a few touch ups (whereby the solution to stalling was upping the idle by 200rpm) I cut my losses and left the car as is. Getting bored with the car I decided to upgrade to some RDA slotted and dimpled rotors, remsa pads and new fluid, got that all for about $550 delivered from Race Brakes. I got all that on easier enough and the braking was marginally better but just a decent upgrade from the now 100,000kms old brakes. Next problem arose with the zf starting to flare and do all kinds of crap. Took it to trans shop to check fluid levels and the like and found out that the box was about 500ml low on oil and potentially causing the dramas. They topped it up and the box seemed good for a few months but started to flare again. Somewhere amongst all this I decided to put some gauges in the car. I ended up making my own fiberglass gauge pod out of the tissue box holder, bought some prosport oil pressure, oil temp and boost gauges as well as a sandwich plate to install them. I think all up I spent about $400 and installed them myself. Again lost track of what order things happened but the wheels copped a coat of purple plastidip and glossifier to try something a bit different. I think it came out pretty good. Come summernats time I thought I would invest in some sound system gear. Quite a mix and match of brands and parts but basically changed the whole lot and rewired everything from scratch. This never quite worked that well and ended up getting a car audio shop to have a fiddle and they got it working well until the next time the car hit the dyno and something tripped the line converter and amp’s and basically destroyed everything. Just not worrying about that anymore at the moment because can’t be bother spending any more on that aspect of the car. It was around about this time that I also got my hand on some matte orange vinyl wrap and gave the car a facelift. The rims went back to normal and the plastidip went on with the help of my little brother. Total cost was $200 and 20 man hours between 2 people. Was pretty happy with the result but quite lazy with some bits and would do it differently if I did it again.
  17. Dion's is 3.7L isn't it? John's was 4.0L iirc. You wanting barra's generally or 4L?
  18. Awesome write up!! So from a $$ point of view if you can get your hands on some worse for wear calipers is it worth buying them and getting all this done or just buying a new set? How much did it cost all up if you don't mind me asking? Wouldn't mind getting some crap condition brembo's and doing this to save money, plus I want a unique colour not red so kill 2 birds with one stone
  19. The control blade spacer won't change things because its the 'knuckle' on the hub that is the problem and a spacer won't move that Everyone says there is no room to move with FG guards but this is a lie. I got at least 10mm more clearance from rolling and pumping my guards, and that wasn't pushing them too far
  20. I was under the impression Haltech are working on a plug and play with the elite but not sure how true that is
  21. There's plenty of copies of te37's with good offsets on ebay if you're willing to run copies
  22. That is the only way to do the rear end of a modern day falcon if keeping it irs. Keep up the good work
  23. Bellato
    In The Club
    I'm personally not a fan of stav's gauge holder. The gauges aren't directed towards the driver and the angle makes it hard to read analogue gauges. The interceptor are digital though so shouldn't be a problem
  24. Guessing that was on et's and the ethanol tune? Must be good cracking a 10 though! Still on stock tailshaft?
  25. I remember reading on here that 19's and 20's can go as high as +42 on a 10 inch wide wheel but 18's can't because they foul where the control blade connects to the hub assembly. I think you can only go as high as +25 on a 10" wide. I could be wrong and it may depend on the style of wheel but just something to consider
