darkness
    Melbourne
  1. I had the same problem changed the valve springs and replaced the coil packs havent had any issues since hope that helps good luck
  2. sounds like a real head ace
  3. can you put a switch in and keep the ecu's auto sensor too?
  4. Anyone want to go for a process west group buy I was thinking intercooler package and all but if anyone needs bits and pieces we can get those as well and see how much of a discount we can get
  5. im having a kinda of similar problem I changed and gapped my plugs a few months ago when I had a misfiring problem and checked coils which looked fine and not problem since but then I took the car in for new valve springs and a new diff since ive gotten it back as soon as it hits 3000 or so starts sputtering my mechanic mate thinks its the pump because he reckons the coils will generally fail on take off said it seems more like its not getting enough fuel could be a similar problem to yours... im going to get the pump changed this weekend and see if it fixes the problem
  6. if its a decent price id be interested
  7. Hi Darkness, I have a set of 18" genuine Option XR8 wheels I was about to advertise on the forums. I see you were interested in a set but they were from S.A. Im in melbourne (Forest Hill).
    They are fitted with Yokohama Advan V103's (sticky as sh*t), but nearly worn out.
    Only 1 rim has a tiny bit of gutter rash, they are near perfect.
    call me on 0416966639 if you wan...
  8. sweet thanks alot guys ill try that and see what happens if it fixes it all good
  9. really? why is that sorry if that's a newbie question I just dont get it
  10. set to .8 or .7 cant remember but it wasnt misfiring just when the car come to a complete stop after a good trashing it gets really shakey like its going to stall
  11. stock boost is 6psi and after I flashed it was running 10psi and yes valve springs are stock could that be it?
  12. yeah I have put it back to stock and it hasnt happened yet so im guessing it could be that but I dont understand why? I have just recently changed plugs and fuel filter as I thought that could be a problem once I flash tune it and was running sweet for a month or two till this happened all I have done to the car atm is a f6 airbox tranny cooler and the flash tune, but it only happened now and then even if I gave it a hard time
  13. sorry forgot to mention it is a ba xr6t
  14. hey guys I have a problem I have recently used a cappa flash tune on my car and the first month I haven’t had any problems but recently when I give the car a bootfull and come to a complete stop it gets really shaky like its going to stall after I drive it again it goes away, doesn’t happen all the time but I cant see what it would be I have changed the spark plugs and fuel filter have also done a service and has only been around 200/500 kms any ideas would be greatly appreciated
  15. nice man its looking good so far gotta come over and check it out once its done
