gsd112
Donating Members-
gsd112 last won the day on April 15 2023
gsd112 had the most liked content!
73 ExcellentAbout gsd112
Gender
Location
Penrith
Mate I get my ZF serviced at Precision Racing. My car has been built by them as well. Same price as my local trans shop for the service.
I had a coolant flush with a new overflow bottle and cap from repco for my FG. Straight after it everytime I stopped it would dump the coolant out the overflow. Tried a new OEM cap and bottle same and then another cap same issue. Mechanic said I had a head gasket. I put the old cap back on and fixed. That was 7 years ago and for the last 2 years its had 470rwkw at 25 psi..
Give Joe a call at Precision Im sure they will help.
I just had a true-trac and stronger GJ drivelines tailshaft fitted to my G6ET and there is no difference in driving normally no clunks no diff whine no vibrations. Wouldnt even know the changes had been done. But its way better when driving it hard its like night and day.
There is also Northmead auto centre. A mate takes his Turbo there and has a tune and swears by them.
- 310 replies
- Car audio xr6t
- pedders campbelltown
- (and 1 more)
I have to agree blacktur8oute . Been to multiple shops over the years including Autotech, CMS and Tunehouse and Autotech workmanship is on another level to CMS and they are better than Tunehouse. I must admit my time at CMS was 4 years ago and Tunehouse before that so things might of improved since then. Ive never had to go back to Autotech after any work or tune for problems. All 3 are way better than a regular shop, I just have had a better experience at Autotech.
- 310 replies
- Car audio xr6t
- (and 1 more)
The polishes are enough to get rid of your swirls. Ford paint isnt known to be super hard. Its not euro hard but is harder then Japanese paint. Might be your technique or it just needed another pass or two with the 500. 80- 90% for a daily is a good outcome. Did you clay bar the car before starting the polishing?
clean throttle body,but with those codes maybe best to get it properly diagnosed by a mechanic.
At the moment it is 395mm from the centre of the hub to the guard. I can go to 350mm and still clear my driveway/ road dip. Since I bought it like this I never saw it OE height. Might head off to a local dealer and take a measurement of a fg G6ET
Hi Guys, Anyone with a FG G6ET on standard suspension with the standard 18 inch alloys would they be able to get a measurement from the hub c/l to the guard front and back or if someone knows the standard measurement. I have a FG G6ET that had been raised when I bought it with standard FG XT springs which has been good due to my driveway situation but that has been remedied and I can know lower it back to standard or a bit lower.
Your best bet is go to both CMS and Autotech and get a feel for both speak to Joe and Spiro. Ive had tunes from both on my old BA MKII. They are both great guys but my preference is Autotech. Will be seeing Spiro this week to work out a course of action for my FG.
sure was!!! Both shops are very very well respected in sydney. It was over 5 years ago.
I had Atomic on my BA and they failed at 15psi. The tuner was adamant it was the valve springs I had done 1 month earlier at another shop. Atomic was no use wasnt there issue they had never had a valve spring fail. Replaced them with crow and suddenly the valve float was gone. But it still wasnt the atomic springs just couldnt happen he said. Buy Crow mate.
I had an old L300 van with buggered valve stem seals and it would use 3-4 litres every 5k. It would puff away at idle then a huge cloud when taking off then nothing till I stopped again. Fixed the seals and it went another 100k and barely used any oil. Maybe .5 litre every 5k
I have no pressure in the system. I can take off my reservoir cap after a 30min drive without any issues what is going on?
