Periklis
5 Neutral-
entire motor that is why I am so confused..
Hello all, I have a stock 03 BA XR6T with a T5 that has a boost issue that after months and months of research cannot be rectified. I am going to take my car to my uncles friends workshop who has a dyno to sus out the issue and I figured while it was there to get a tune done. I am not looking to get any huge power gains just a decent tune to go with the stock set-up. Question 1: I have seen afew early model capa tuners on ebay that are blank or have 1 or 2 flashes left in them.. The guy who has the dyno has not worked with XR6T's before and said if I can supply him the hardware required he can put it on the dyno and tune it up for me. He has no software whatsoever, does he need software to tune the car with just the capa box? What are my options here? Question 2: Are the early model capa flash tuners ok for the outcome I am looking for? I have done no mods and am not planning on doing any apart from the centre muffler that has been removed. Any advice is VERY apreciated. Thanks in advance.
it just does not make sense, since the car was doing this in the old motor I had in it, and now with the replaced one its doing it again..
- 16 replies
- stuttering
- loss of power
- (and 5 more)
is it a good idea to just go put it on a dyno? ive literally run out of ideas..
This just does not make sense because it was happening before I threw a rod on my previous engine, this is now a new motor with a replaced turbo, and a replaced cat...... any ideas?? this topic seems to be so popular but not defintive answer... its killing me
I have a similar problem, as soon as my boost starts winding up the car backfires and breaks down and then goes into a shake almost like it is in a 'safe mode' then afew revs gets it back to normal, happens to me as soon as I come into boost..
- 16 replies
- stuttering
- loss of power
- (and 5 more)
car has started doing it again.. ive seen afew threads with same problem but no solutions?? anyone with any ideas?
Hey guys, Ive done afew searches but cant really find anything similar to my question. My question is, I have a completely stock (centre muffler removed) 5 speed ba xr6t, and I want to purchase an ebay monza cooler that fits directly on to the stock setup. Will I need a tune after doing this, or will this be okay since my car is completely stock? Thanks in advance, P
I'm having identical problem, anyone found a reason?
Losing Power/boost Under Full Throttle As If Choking :(
Periklis replied to Tim Staunton's topic in Engine Workshop
Exact same problem I am having, although mines tottaly stock.. Did you end up working out what the problem was? I replaced my coils with second hand ones roughly 8 months ago, changed the spark plugs, they are currently gapped at 1.1 which I was told was stock gapping.. -
I have same problem but mines a completely stock 02 5 speed xr6t
no same sort of power, doesnt happen all the time, but when it does it really struggles to wind boost without backfiring in 1st and 2nd..
