j.d
j.d last won the day on June 15 2012
j.d had the most liked content!
204 Excellent
About j.d
  • Birthday 26/02/1989
    Eastern Suburbs, Melbourne
3,745 profile views
  1. CJF077
    Happy Birthday j.d!
  2. CJF077
    Happy Birthday j.d!
  3. ute? 35mm spacers
  4. Spotted xrt270 in doncaster last night silver fg, any1 from here ??
  5. Edit: oops
  6. Guards rolled?? Shortened axles?
  7. Need spacers to make it work !
  8. whats my ute doing? Keeping your nature strip company?
  9. mine is lower then "recommend" at the front and its sweet, I was using 19x8.5+0 with a 245/35/19 scrubes over everything but looked so good I didn't care haha, depends what your willing to put up with form>function haha
  10. Should be sweet with a 15mm spacer still.
  11. I wouldnt use a 10mm slip on. I am using 20x8.5+7 scrubs a little over big bumps I did 20x8.5+17 and no scrubbing whatsoever.... Both with 225/35/20 tyre !! And by that I mean 20x8.5+42 with a 35 and 25 mm spacer !! If I were you I would go 15mm bolt on spacer if you don't want to go as far as a 25mm, you need to remember tyre plays a big part also !! You said u had a 225 tyre? 15mm spacer will be fine
  12. I have the same, 5mm spacer will work, or you can be like me and use a 35mm spacer but will need to roll, or just use a 25mm spacer, and no need to roll.
  13. our centre bore is 70.5 I would be getting 72mm not 76
  14. Will poke, u will need to run stretched Tyres
  15. . I would be going +20 fronts and the rears should fit ! But I don't have a sedan will they hit on the inside (rears) anybody with a sedan?
