datjas
  1. thanks guys
  2. HI all I have a 04 xr6turbo 120000klms with xr8 bonnet 19inch bobjane alloys has the premium sound package cloth trim,it is standard engine wise apart from battery relocation hybrid cooler kit with deletion of the crossover pipe and copy plazmaman airbox with pod filter,roof lining needs replacing,what is a relistic price?I should put on as I have someone in my family going through bad times I need to help out I need to move the car on to get rid of the loan Thanks in advance for some advice
  3. Sorry yes I meant higher ratio's as if it was 3.08:1 going to 3.45:1 seen a couple of 4.1 complete centers for sale.
  4. Has anyone changed their diff ratio in their everyday xr6t,Id like abit more off the line does feel like it could do with taller ratio,s.My car is an 04 ba xr6t auto.I have done cooler and piping battery relocation to passanger side and also pod filter,plans after this are to fit my 4inch dump I have the 3.5 inch x force rear half and twin outlet muffler to fit once I get my exhaust housing back from the fab shop and will do the mid section myself.Will also be doing the usual wastegate actuator with my properly ported housing and oversised flapper,springs,injectors,fuel pump and flash tune as everyone does,With all that done what do people with experiance think about doing the ratio's, Worth it or not?When the car is finally tuned if it makes 300kw ill be happy to leave it there for now with the auto.
  5. Should of added cant beat making parts like this out of thick craft cardboard first to make a templete you can bend it put screws through it to hold it together if you cut to much just add masking tape and recut.
  6. I got carried away made my own bracket to mount my battery to the other side after getting a second hand cooler kit and really didnt want to keep the crossover ect,if someone tutours me how to scan and upload ill share these templetes which started from a rough copy of the plazma man kit I believe,took me about 3 days off and on as its my every day car,bits each night trial fits than paint,I already had fitted the cooler kit and changed the pipe work to not use the crossover so had the pod on the pipe already.I made it all out of an old parking sign approx 1.5mm alloy. near copy of original plazmaman I just changed the way it follows the fuse box top painted with crease line done,hard to do on a table out of an old parking sign haha, mucking around trying to get the base right,very hard to bend up with just a small vice and a big shifter,used alloy L section to clamp in vice for some bits finished in the car,spent alot of time on the base piece profiling it over the pipe feading the turbo from the pod to the turbo in and out but the old sign cost me $10 and another $60 for the pod filter piece of three inch stainless pipe with a bend on it and the silicon joiner from pipe to the compressor housing.
  7. So have I got it right after you cut the old nut off you just screw the new nut into the pump and the old hose will just push in and clip to this once in?
  8. my hdi kit is 2 and three quarter is that strange?
  9. How do you tell if a used flash box has been reset?
  10. Even if it sounds like an Rb its hard to miss the turbo on the right hand side of the engine bay in the dyno vid
  11. tiger's
  12. geez how can I make my job sound better, Im a surface technician at riviera marine,(gelcoat and fibreglass repair and detail)haha
  13. so ive got my aftermarket cooler pipe set up and pod setup causing overboosting,if I do the bigger wastegate port will that let my car run close to stock boost again nothing else is done at all yet
  14. datjas
    Overboost
    I have an 04 xr6t I did a pod filter and hybrid cooler all seamed fine but when I fitted the xr8 bonnet I changed the piping and got rid of the crossover and now it hits whatfeels like a soft rev cut is this boost cut I'm feeling the boost gauge appears to hit near 9 psi before it does this and yes it has new correctly gapped plugs
  15. datjas
    Zf ?
    id be happy enough with it full manulised,well ive sold his engine now and pulled everthing else out hes keeping for the bf he changed over with the insurance ,pulling burnt cars apart is not fun at all,just have a rear end left now to sell and the box is mine,Thanks for the info though veva I didnt relize it had internal cpu.
