Marsh
  1. Xf Falcon thanks for sharing do you have any more pics.? Looking for a shot down the turbine inlet? Also what size waste gate is that? Tochi, Twin scroll one would be ideal to see looking down the exhaust inlet did you get this sort of pic of yours?(nice Capri BTW) I was going to ask in your build thread but didn't want tO disturb
  2. This setup uses a custom manifold. Location of wastegate would make for easy wastegate adjustments/spring changes though. Keep the photos coming I need ideas Henz... Is there something ilegal about an external wastegate? (im serious I dont know)
  3. Is this on an Xr6t or is it the car in the photo that you have posted earlier?
  4. Any links to his threads? Tochi have you got any details on who did the work? And if you have had any issues with it at all. I don't see how your setup differs in theory to the 6 boost manifold, port location is only 30 mm up stream and on the other side of the flange.it has the same angle
  5. That was one of the queries I had but looking at some setups from reputable manifold builders I have noticed that most of the time the waste gate has this sort of orientation This is a 6 boost rb26 manifold w.gate is at 90 deg
  6. Was wondering if anyone has tried anything like this...... A T3 rear housing could be used with an external waste gate and you get to keep the standard manifold? Giving you a few very good options as far as T3 rears go anyway Just reading the forum and it looks like most ppl are sort of stuck with T4 .7ar front /standard rear or they go the whole hog with manifold and T4XXXR How much can the stock fg manifold handle? My guess it would be enough for 80% of the punters If anyone has any advice or comments I'm all ears
  7. .
  8. Marsh
    Fg F6 610 Rwkw
    Awsome setup. What size is the rear housing on that turbo....(can't believe no one has asked?) Out of curiosity how often do you have the bio fuel in the tank? Well done! should do a slippery 10
  9. I have these on my wife's n/a xr6 and they are by far the best tyre I have had on a car. I will be replacing the fg utes tyres with these also.you won't be disappointed
