FIXR7
19 Good
    Perth
570 profile views
  1. Just found this.... http://www.gt5.com.au/
  2. Reason being, I tried these Koya Drift Teks for size in 18x8.5 +15 and 18x9.5 +15 and they worked pretty good. They will do them in Custom offsets from +15 to about +45. I actually bought these for my XH and +15 is as low as they make em(I wanted Zero) so I used them with spacers on the XH. Only complaint I have is the "Custom" colour is far from a professional job @ $100 ea!? It's barely better than a spray can job and obviously they just painted straight over a set of black wheels....hardly a good idea for a silver finish! It looks more like grey.
  3. Hey Tom, Do particularly want a 10" rim or will a 9.5" suffice?
  4. Do they really mean that they won't buy them at that offset or that SSR actually don't make them that way anymore? I had similar conversations with other wheel "Distributors" and they basically lie and say that wheel manufacturer X doesn't make them anymore. only to find they do when I contacted the manufacturer or overseas Distributor.
  5. Check this out TomT. http://www.ssr-wheels.com/
  6. Well actually here are alot of them that will fit and they are available in many or custom offsets. It's just that most people don't want to pay for them.
  7. Yes they'll fit. But it depends on the wheel offset as to whether they hit anything.
  8. Do you mean stock R35 wheels? Obviously you did some guard rolling for your XR8?
  9. Cheers Barnz. Tocchi, what are you running on your F6 ute? Every time I think I've found something for mine there's something that knocks it on the head!?
  10. Got some 18x8.5 (+15) and 9.5 (+15)Koya Drift teks with 235/40 and 275/35's for my XH work ute the other day and tried em for size on the green one.... I think they look ok but are a little too small in diameter for the FG. They didn't rub except for a very slightly at the front when turning into a driveway.
  11. Yeah and which Tenzo R wheels? there's lots of different ones I see.
  12. Thanks Mummba, Yes I have measured and I don't get 50mm. I get 33mm rear and about 31mm front which are already pretty well rolled stock. Of course if the rears were rolled, that would probably give close to 50mm. I'm worried about doing that because I don't want cracked paint.
  13. Punching your 9.5" -15 into the calculator brings up 70.1mm more poke than stock!? That would suggest I could easily use a 10" +10 which gives 51.4 poke and not necessarily have to roll my guards? Or did you have to pump and roll yours to get it to fit?
  14. No wuckers man, Thanks anyway. So it sounds like you're saying that if you used a zero offset with a 9.5" rim you could get away without rolling the rear lip?
  15. So mummba, 9.5" -15 that's not typo is it? What are you running now? I'd like to meet up and check it out if that's ok?
