rboksic
Everything posted by rboksic
  1. matey, How many XR6T engines are there in the USA ? For that matter, How many XR6T engines are there anywhere, other than in Australia! What we want is a tuning package which operates properly for the XR6T, and that only comes about when someone sits down and nuts out the software to interpret the CAN communication codes for all the specific sensors on the XR6T. The job would be quicker if the info was freely available from FORD Australia, but I'd imagine what's necessary, is someone dedicating a fair amount of time to "cracking" all the info required using CANbus capture package, in conjunction with the FORD ScanTool. It takes time, and dedication. The Holdens run similar donks as the huge US market, so simply based on volume sales, don't expect a dedicated Australian FORD product to be as cost effective or as good as the GM unit. But then again, Tuna is a whiz, and maybe he'll surprise us with an even better version. We can ony live in hope..... What's the go, tuna? The new 05 Mustang runs Canbus same as the T
  2. rboksic
    Fuel Pumps
    Great Idea, How did you hook up the factory fuel line again, it appears to be a Heat and shrink item, I cant see how it could be re-used, please do tell. may be he sent the whole pump assembly and that's what he changed? Only takes 30 min to replace pumps if you have an empty fuel tank (Chopper) Rob
  3. rboksic
    Fuel Pumps
    Bosch motorsport
  4. Optimax has a short shelf life. A guy that sets up ciruit cars told me that he could get better power then the supplied fuel was fresh , as staright from the plant,then straight off oth truck Rob
  5. Rob, good time, well done. was that with a custom tune or still the generic tune? Custom tune and all stock
  6. The new Selby Cobra must be rice as well It has a Carbon fiber body and a real engine V10 Rob
  7. Only 4 T's 1 XR8 We all had a chat at one time or another. and it was a 13.199 107.44mph
  8. Craig, what presures are you using at the drags ? with the MT Rob
  9. $700 up
  10. Nick, YOUR ALIVE! Rob
  11. No matter how big the duck behind thr grill is it still only gets its air from the gap betwwen the bonnet and the radiator support whitch is not much. Phoon CIA is the goods. as a side note SS inductions on a LS1 looses 10 to 15kw Rob
  12. E10 94 or 98 ?
  13. that's only if they allow the options to be used Rob
  14. Chris, You get what you pay for with Spec homes, You may need to learn how to speak various Asian languages, ask Damien about his place. Rob
  15. Im sure you could. But he picked up the chip for $400.. Custom tune of a couple hundred and he will almost net the same result as the edit, for about $500 cheaper! Good on him for modding in the first place! How do figure $500 cheaper? Cappa flash with genric tune will match the Custom APS tune. Rob
  16. I have seen it a few times in the last couple of years , last time at Christmas at Foster it looks worse in real life . Rob
  17. I have seen it as well , the grill is made from Stainless flat bar.
  18. rboksic
    Tattoo
    Ian he has a tattooing gun and wants to practise. Not a gun that shoots bullets. Geea. Well I have the latter you can run but you can not hide
  19. Is it for Commmodoors? or the ford
  20. Good tip on heating the old hose . I will now look for some better in tank fuel line. Rob
  21. Is it one like this www.ventura.co.za/assets/auto_generated_images/img_580ee122.gif “Donut” oil cooler The “Donut” cooler fits between the oil filter and the engine block. They are available in 2 sizes: 48 and 57 mm thick. An extension bolt with 3/4”-16 UNF thread is supplied. The cooler has 16 mm water connections that must be connected to your car’s cooling system. This cooler is ideal for off-road conditions where dust or stones may clogg oil-to-air oil coolers. Rob
  22. Is your T running like crap if could be the fuel line that connects the Walbro pump to the pump housing . Mine has lasted 6 mths ( the hose ) My car started to run like crap , would not exelerate but would drive at small throtle aplliaction. Got home and pulled the pump out to find the EFI rubber hose split at the barb . Moral of the story USE EFI hose clamps. Yes I was concerned if I had did some damage to the car now relieved
  23. go and buy a typhoon snorkel; and fit it to your filter box take 30 min's SS reductions
  24. thanks. looking for barra
