rboksic
Everything posted by rboksic
  1. The little planes are called "Extra 540" the new ones the older ones Extra 360 . The blackhawks can be launched from ships as well
  2. He has only asked if you could fit the 2 spot std caliper not the front rotor as well to replace the 1 spot that's std.
  3. That looks Ugly
  4. rboksic
    Cv's
    They where first advertised at $3800 a set on the LS1 site.
  5. accutally with the amount of inquires we're getting from down there we planning that in the new year. The main target at the moment though is to get the new shop up and running and our new zealand dealers better equipped ← Where is the new shop? Rob
  6. MATE TURNING THE STEREO UP WILL DRAW MORE POWER THAN THIS THING. A SMALL CAR LIKE AN MX5 MAY BE WORTH WHILE, THOUGH NOT A BIG ENGINE LIKE THE T. THOUGH I REALLY HAVE NO IDEA. SCOTTY PS SORRY ABOUT THE CAPS, COULD NOT BE FARKED GOING BACK AND CORRECTING. ← What Factory amp runs at 46amps count them 46
  7. Avgas 100/130 is dyed green The 100/130 grade within each of these specifications has a lean mixture Motor Octane rating of 100 and a rich mixture Supercharge Octane Performance number of 130. Currently, there are 22 approved “Issuing Organizations”, mainly speedboat, hot rod, and speedway, but including CAMS and the Australian Historic Motoring Federation (GPO Box 2862, Canberra, ACT, 2601). These groups issue “Leaded Fuel Passbooks”, on behalf of the government, to members of their associated clubs which allow the purchase of Avgas from your local supplier (mainly airports and race circuits.) Hope that helps
  8. yes they fit on the front but it depends on the size of the rotor 330mm I think is the max diameter
  9. It will be a quick way to kill your electrical system due to the extra load As they say if sounds to good to be true it probably is not.
  10. rboksic
    Ebay Seller
    the only worry is that Ebay gut whant's 2 time more than its worth new
  11. Save the $400 on the SS Reductions . Dont BF's already have the 2nd CIA?If not put in a Typhoon 2nd CIA $60 parts cost and it will do a better job.
  12. its $58.60 a barrel now dropped $4 bowser is back up to $1.25 for ulp tackes a long time to go down but goes up in an instant
  13. Edit
  14. rboksic
    Afr's
    leaner due to thinner air less O2 having said that 1300 mt is on that high so it may only be slight change in AFR's at WOT
  15. Gates is the only one that makes it as far as I am aware
  16. Soon as you mentioned a drive and make a stop off at kebab shop I knew CRO would be first to reply
  17. Thanks! ← you need 80mm 3 1/8 inch x 45mm long hose not 76 mm
  18. Gates submersable fuel line is $60/300mm and that's how it is sold . EFI fule hose is not made to be used in tank submersied in fuel. Take it back get them to fix it .
  19. N/A 6 BA XT 2003 sedan, my thinking is if it is cheap enough even if it only provides a few kw for a N/A a few is better than none ← If you whant more fuel why dont you just change the fuel reg. to one off a turbo would be a lot cheaper
  20. no it should not be out as the injectors scaling in revised in the edit from my understanding
  21. Bozenjack (spelling) eng at wetherill park, just off redfern street. ← Bosnjak Engineering Address: 8 Blackfriar Pl Wetherill Park NSW 2164 Phone: (02) 9757 2133
  22. concrete should be bout $55/m2 not inc pump or excavation. AS to how thick, well that depends on a few things, is it clay? is it on fill? is the natural ground flat? for the sake of $200 odd dollars go the 100mm. Does the price inc remote doors? slab? drive pads? ramp if required? window? power? council wk is sfa, u now use a private certifer any way.The 8k is good if you dont put your hand into your pocket again. Look in the trading post for 2nd hand ones as well (especially if your handy). I sold a 7x8 one in perf condition for $1200.00 last year. (you pull down though) ← $55/m2 for concretre as they would say on "the Castle" YOUR Dreaming Try $150/m2 if you have an account . 6x6x 125=4.5m2 6x6x.15=5.4m2 + footings F82 is about $85 a sheet (6mt x 2.4mt) = 2 sheets Plastic chairs 20 cents each. When I did my garage 2 yrs ago I had to use face common bricks and have a teracotta tiled roof ,windows had to be timber. $7k was for 1 Roller shutter and a roller door both remote Total cost $40k+ so $8k for a complete garage + slab is good Power and data can not be run in the same conduit. if you have 3 pahse run it to the garage if you think you may get 3 phase run 3phase Rob ← 36m2= 3.6m3 (allow 3.8 @$138.00/m3= $524.4 + $80 del steel sheet 3 sheets (6x6) f72/ $51.00/sht =$153 + $45 del chairs 1 bag $ 21.00 sand allow 3m3 @48/m3 delivered= 144 so there for materials= $967.40 labour 2x concreachers @ $300/ day x 1.5 days= $900 total= $1867.40 $1867.40/36 + $51.87/m2 mate I built 38 houses last year and $55/m2 was and is spot on for small jobs. As I stated previously, no pump and no earth works. I think you are getting m2 and m3 confused. ← You are right m2 and 3m confused
  23. concrete should be bout $55/m2 not inc pump or excavation. AS to how thick, well that depends on a few things, is it clay? is it on fill? is the natural ground flat? for the sake of $200 odd dollars go the 100mm. Does the price inc remote doors? slab? drive pads? ramp if required? window? power? council wk is sfa, u now use a private certifer any way.The 8k is good if you dont put your hand into your pocket again. Look in the trading post for 2nd hand ones as well (especially if your handy). I sold a 7x8 one in perf condition for $1200.00 last year. (you pull down though) ← $55/m2 for concretre as they would say on "the Castle" YOUR Dreaming Try $150/m2 if you have an account . 6x6x 125=4.5m2 6x6x.15=5.4m2 + footings F82 is about $85 a sheet (6mt x 2.4mt) = 2 sheets Plastic chairs 20 cents each. When I did my garage 2 yrs ago I had to use face common bricks and have a teracotta tiled roof ,windows had to be timber. $7k was for 1 Roller shutter and a roller door both remote Total cost $40k+ so $8k for a complete garage + slab is good Power and data can not be run in the same conduit. if you have 3 pahse run it to the garage if you think you may get 3 phase run 3phase Rob
  24. 16psi was to high last night . Broke traction at the lights just a bit then just before it changed to second then again in second (a chirp) 5 runs at 12.723 to 12.779 @ 111.77mph 2.102 60' with no warming of the tires with just a Tune 250kw approx. performance mode let it do the work
  25. the orange xr6t was doing 12.738 at 111.9 mph fastest run slowest 12.779 at 111.2mph 5 runs he could do dial your own
