rboksic
Everything posted by rboksic
  1. Can any of the Darwin crew give me some names/contact details for fishing guides that you can recommend. I have one or two days free on the 15/16-5-06 I will be there on the friday 12-05-06 Any help would be nice Rob
  2. Your mates wrong. the rubber is delaminating at the joint , my mate is a rubber molder I had all 4 changed at no cost and they did 28k km
  3. may be time to go shopping elseware. injectors $500 1hr to fit springs 200 + fitting
  4. its not in the treatments it 's strength comes from the forging process to make the billet and the type of steel used tomake the billet.
  5. At a very good guess Afr's 13.2 -13.3 at the top end.
  6. rboksic
    Nasho Run
    I will be with you guys in Sprit, while pushing ZZZZ's
  7. I have a mate that does / has done DVD's or tape for The Mad Turk Summer cruise? But he is in sydney. I can see him if you want.
  8. Funny you would say that as most of the guys where from sydney
  9. 12.5 is in the money
  10. It's a *beep* of a job and yes it's not clear in the manuel and I have forgot how I did it. sorry !
  11. rboksic
    New Edit
    Been out in the US for over a year. Some time this year it will be here , Commodores will be first I was told. I saw one in the flesh last week. Rob
  12. Water in methenol is a problem in Methenol only cars, not when its mixed into ULP/Pulp. If you have finnished racing for the day you either drain thr fuel tank or top it up to capacity to minimise the surface area of the Methenol has . Rob who does not what to be in a pit crew.
  13. I have seen them at the car shows , they supply and fit for ford.
  14. Bret, the ford iridium ones are only $60 for the set. Rob how's the fishing?
  15. Are you for real? Fibreglass stripper!?? I have some thinners I use at work for adding to lacquer when spraying clear coats on furniture, comes in 2 drying speeds too. Maybe that would be the go..... Its only geting rid of the wax on the mold. A mate uses it to clean metal parts that are to be rubber bonded. 10 % tolly is ok its the same as putting Octain booster in only cheaper 60c to $1 lt
  16. $500k sounds a bit extreme and hard to justify and would assume it would cost around $50,000 - $75000 to reliably build that much horsepower. Regardless of the cost it's an awesome effort. Robbie. the 550k I think is a total to date he has spent so far, he has had a lot of problems.
  17. $450 with pig tail lead
  18. rboksic
    Road Toll
    Brian, did you feel that all you did was raise the Governments coffers. I belive that on most freeways 135 is a safe speed if every one kept left and not be dickheads. In Europe 200kph+ is safe on similar roads like we have but drivers are better trained compered to ours. ( I did 175kph for about 10hrs ). The Govenrments dont care how many people die on roads , they just want to make more on fines. Rob
  19. Macka, I have talked to the guy from EMS , load point every 25 or 50 rpm ( 1 or the other ) if you want. the more load points the finner state of tune you will achieve eg lets say you have a dip in power/AFR's/torque at 2500 and 2700 you can do 8 load points to fix the dip if required. So move the better . Rob
  20. that's only for the competors not spectators you will find will be covered buy public Liability Rob
  21. They just had a 2 day meet 26/12 and 27/12, staff beening over worked. Anyhow was 32+ that arvo allways next year
  22. 28+ at the moment
  23. Muzza, So the Truck has a new box ? dam those heavy skip bins Rob
  24. Turbo6man, if its over 30deg air temp it will be a sh*t night, I went last week and never again when its hot Rob
