nxr06
7 Neutral
About nxr06
  1. nxr06
    Workshop Manual
    Hi Looking for workshop manual for Fg XR6T -hopefully via a download link......and maybe free
  2. Atomic Stage 4 Plus..... It had washes not shims in there when supplied with the long motor, but when the engine was hot I'm guessing that it may have kept a valve or 2 open as it would wind over and not start like it had minimal compression, and be find again once it cooled down. I removed the washes which did seem to make the engine much better hot and cold starting, so now im assuming I should by a shim kit and do them properly. I just assumed the standard roller base circle would still have been like stock, but maybe not. FTR: I had the vernier gears in, as supplied and changed back out to full VCT functionality which is where it is at now
  3. Anyone else had to shim the atomic cams?
  4. update QLD Ben Dennis / Auspeed / BA XR6T Sedan / Auspeed Tuning / Palmyra / 10.56 @ 128.74MPH thanks
  5. Hi rednose could you please add me to the list: second run in car with this combo QLD Ben Dennis / Auspeed / BA XR6T Sedan / Auspeed Tuning / Willowbank / 10.61 @ 132.53MPH
  6. What did u end up finding with this?
  7. I would agree with this statement also ... but in an attempt to give some indication based on what I have experienced... 350-380rwkw would be about average of most healthy ZF's surviving. The moment they go over 400rwkw you could safely sat its a matter of when it will fail..... I
  8. so are these issues linked to the new x4?
  9. Whats your thoughts on this? It would be very rare for an fg mk2 to have any physical faults.
  10. it feels like there have been increasing number of pcm issues since the x4 came out or when hp tuners released zf capability..... Not sure if there is a link but interested to see if the cars sh*tting pcm's have had more than 1 tuning product used on the car when it sh*ts the pcm...
  11. I have fried a BA ecu with an X4.....
  12. Agree......
  13. nice kit dave
  14. <p>Hope they make more of an effort to complete all vehicle definitions properly to have at least as many tables as SCT does.....</p>
  15. I fitted a plazmaman front-mount kit... not sure if they still make them .... The heat soak is that bad on the stock ones it's a must do mod.....
