gazman1968
About gazman1968
  • Birthday 28/03/1968
    Melbourne East Suburbs
  • Interests
    FORDS, OWN 66 Mustang Convertible, 79 F100 4WD, Turbo Territory FOOD & wINE
  1. Happy Birthday gazman1968!
  2. Happy Birthday gazman1968!
  3. Happy Birthday gazman1968!
  4. Happy Birthday gazman1968!
  5. Hi Check out NIZPRO in Bayswater they have packages to suit TT
  6. Hi I have noticed a whine coming from somewhere stuck head underneath car and bugger me sounds like it might be the fuel pump would this cause my vehicle not produce the numbers when putting the foot down under load ? As I said it cruises fine. Cheers
  7. Cheers thanks guys, I will do plugs first then coils if necessary. Sounds like FoMoCo is the way to go !
  8. hI THANKS FOR YOUR HELP, WOULD FG COILS WORK ??
  9. Hi doesn't matter what the outside temp is, I have retuned on numerous occasions in different types of weather has just been progressively worse. ANNOYING, I CAN'T EVEN OVERTAKE LIKE I USED TO !!
  10. nO, NO MODS TO FUEL PUMP
  11. Hi what is the best plugs to use and also which coil packs . NO BULL
  12. Thanks, for info this has been happening over a period of time when it first started I'd just plug the SCT and retune, it would work for a while then start playing up again, until now no matter what tune I put in I still have the same problem, I,m getting pissed off and hope it not the result of a poorly tuned vehicle (NIZPRO)
  13. I hope some one can help, at any more than say 75% wide open throttle /load car just burps and farts with F.A. power ?? I have SCT Tune, 100 cell Cat, k@n Filter Nizpro injectors and tune on 98 Ultimate, typhoon intake, debung exhaust (Yes it's a Territory 2008) It cruises just fine if dont put the pedal down, engine puts out around 300 kw, WHEN IT WORKS !!!
  14. Happy Birthday gazman1968!
  15. Hi does anyone produce hi performance leads for Turbo ? I suspect my stock leads are breaking down, do I just replace with FORD items or is there something better out there ? Cheers
