KAL_SPL
2 Neutral
About KAL_SPL
  • Birthday 17/05/1976
Contact Methods
  • Website URL
    http://www.cardomain.com/memberpage/490759
  • ICQ
    0
    Kalgoorlie WA
  • Interests
    Car audio
  1. Happy Birthday KAL_SPL!
  2. Happy Birthday KAL_SPL!
  3. Happy Birthday KAL_SPL!
  4. Happy Birthday KAL_SPL!
  5. Ended up hooking line converter up straight to sub wires output from factory amp and its thus far worked flawlessly for a week , unsure what the amps output is from factory but seems my line converter is handling it ok.
  6. Was pretty sick if Im honest , not a Ford fan but credit where credits due.
  7. Yeah that doesnt help youre right , the plug in the rear has an orange sheath with white and orange wire and a black sheath with yellow and brown wire. Guess I just hook them up see what happens , hope I get the phase right
  8. Dont suppose you have the colours handy , they are different to the old blues and pinks they have been since day 1.
  9. that's what Im doing mate but I want to use the 2 pairs of wires coming into factory amp that is no longer needed , the pairs have an orange and black plastic sheath over them , just wanted to comfirm these are left and right , surely someone has a pin out for the plug in the amp ?
  10. Got couple of vids of your 400m powerskid if youre interested.
  11. Fitting an aftermarket amp and subs to FG XR6 for customer , can anyone give me the line input colours for the factory amp , theres 2 pairs of wires and unsure if they are left and right or what ever , did a search but nothing has come up about the actual colours of wires needed.
  12. You will have fun trying to put your seat belt on when the buckle is on the same side as the belt ... The cushions them selves could probably be removed and swapped over I suspect.
  13. As cautious as I was to do it I was still sceptical there would be no issues , but Im proud to say everything works 100% and I drove the ute 600km to Perth and it functioned as per factory. It is deffintaely not an easy task but if I can do it then I dont see why anyone else cant with a bit of initiative.
  14. Not that I have actually looked at 1 but Im assuming they will be 2 blues and 2 pinks. If those 4 wires are there then they should be it.
  15. Without going into extensive detail , its possible to fit double DIN in the same way I have done this 1 , the main problem will be if its a sedan you wont have the space where the airbag is so Im not sure what else you could do. Everything in this is still functional and nothing interferes with the dash or normal panel locations , it depends what your willing to sacrifice in way of destroyed panels and the fitters ability to hide modeules/modify wiring harnesses. Glad you like the skids not bad for a v6 commy with a clubsport kit ay haha
