Hi all, I have a BAMKII which has 83,000km on the clock. I've owned the car since new and it has never missed a beat. Recently I decided to give it a tune, being a little cautious the car was tuned up to around 8 psi and it started backfiring. The plugs were regapped and this problem went away, however the car started missing when under load at about 3000RPM. I thought maybe the plugs may have been a culprit as they were 83,000km old so replaced them, I put some new plugs in regapped to 0.7mm and the problem seems to be worse and sporadically occurs at higher revs as well, so I thought I'd ask a few questions to help me diagnose the problem. - After reading a number of threads I'm suspecting an issue with coils but would like to know why this would not be noticable when the car is running 6psi, does a weak coil become pronounced when running more boost? - When I changed the plugs my spark plug spanner kept losing its rubber so I placed a little bit of silicon lubricant on the rubber to allow the plugs to slip out, could this be a contributor? - When I removed the ducting for the turbo from the trottle body I noticed that the rubber mount has a small tear in it, it is under the hose clamp and if it was letting pressure out it would only be a small amount but would this cause the car to miss? I may be missing some power if I have a leak but I would be suprised if it would be the culprit for the miss. (this will be getting replaced) - Finally, I've heard that coil packs can be tested with a multimeter to test if they are strong/weak. Is this true and does anybody know the process as to make diagnosis a little easier Any assistance would be appreciated. Cammo
