Stazza_Brendan
Everything posted by Stazza_Brendan
  1. On the bus home from work.. Just sucks I'm the last to get off.
  2. If your putting pump under drivers seat.. your doing something very wrong.
  3. What exhaust do you have?
  4. They pop up on eBay a bit. But bidding gets fierce sometimes. Seen them go $200. Have you put dividers in the tub of the ute? 2 bits of timber and no more stuff sliding all over the place.
  5. Sold my stock turbine housing for $200. Might go towards new injectors
  6. Your not the only one who rates Achilles as bang for buck. Ive got them. Trav with 400kw runs them.
  7. 2 weeks off work and first one back is a night shift... But in better news found out I'm getting a permanent job. Which is good news considering the downsize of the local mining industry.
  8. When we had our member meeting Monday night Calder were supposedly finding out the problem that Monday or the next day to get in touch with us to borrow ours spare parts if that was found to be the problem. I know they had been dead for a few weeks. This is the only info I know. Our track doesnt discount if the time boards dont work. Time slips still print normally and usually times are announced over PA.
  9. We run the same timeboard setup here in Mackay. They are very temperamental but its the only system that talks to the timing system on the track. We have a heap of dramas with ours, mainly due to weather. Theres almost no one in Australia who will touch the electronics associated with the timing boards. Usually the broken stuff gets sent to the USA to get fixed.
  10. I bought the Plazmaman one, It comes all assembled ready to go straight in, Hoses all line up perfect. Installed in no time. Almost dont want to install it because it looks so good lol
  11. Custom lowmount?
  12. Also compared to the PW or Plazmaman ones this only has 1 rubber ring around the pump to insulate noise. The PW and PM ones have the rubber around the pump and the bracket is rubber mounted as well.
  13. I think all his topics are gooonnnneeee. I think the one you want to see is the link that's broken in his sig, increase power by 10%
  14. When ETM was on here I remember seeing he was pushing the stock location manifold quite heavily. Turbo sat in same spot, everything bolted back in place as if stock but made more power on the same boost.
  15. And a dump pipe, new/modified oil/water lines, modified hotside pipes. Seen a GTX make 458rwkw on pump 98 on a stock motor. Whats the highest power on a low mount?
  16. You can bid a hundred if you like
  17. Doubt they are going to close from what ive heard last night at our local drag club meeting. Apparantly the time board problem is being sorted out and Calder might be borrowing our spare control box for the timing boards and buying a brand new one. If they were shutting shop they wouldnt bother with a big $$$ part that's not critical to running a meet.
  18. Someone should buy my stock turbo housing, http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=181024016795
  19. Dave Sheehy. CPV. Only got 340kw max as injectors stop me from going any higher. Makes 1100nm though and drives awesome. Very smooth power curve.
  20. Getting a tune. 340kw at moment which is what I wanted.
  21. Delayed flight.. now get home 4 hours later then scheduled.
  22. Its how most if not all battery relocation kits are wired. Brothers G6ET is done this way
  23. 4 teenage girls decided to light a fire in toys r us store. Toys r us, autobarn, clark rubber and sams warehouse all up in flames. Can see the smoke from other side of town.
