ZeForce
    Adelaide
  1. What about the CAPA direct replacement cooler, probably one of the cheaper options.... BA-BF XR6 Turbo CAPA Replacement Intercooler Kit. - eBay Intercoolers, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 26-Jul-10 10:27:42 AEST)
  2. Im looking for a cooler which will consistently hold 300ish kw as well, what is the direct replacement plazmaman cooler like? Is there anyone running one of these that would care to comment on them?
  3. You should be using roughly 30% more fuel with E85 compared to PULP. Also, it's not just the higher octane rating which makes more power, even though E85 has less energy per volume of fuel compared to PULP once you factor in the stoichiometric air/fuel ratio of E85 which is around 9.7:1 vs 14.7:1 for PULP, it actually releases more energy per volume of air.... There is a united petrol station on tapleyhills road http://www.unitedpetroleum.com.au/distributor-e85-locations.asp
  4. I just purchased one of these FORD BA BF TERRITORY IPOD IPHONE CABLE 5 VOLT CHARGE - eBay Accessories, Cables, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 21-Mar-10 23:59:47 AEDST) works great and charges the ipod as well I have tried FM transmitter as well they are sh*t....
  5. 1. xr6turbo_chick 2. jetboner 3. bloosted 4. SPOOLAX 5. Andrew 6. RSK 7. dubs 8. topghia 9. Southside 10. ZeForce
  6. 1. xr6turbo_chick 2. jeturbo 3. bloostey 4. SHAUNY 5. Stuart 6. Spoolax 7. TOPGHIA 8. Uterous 9. xr_baby 10. dooly78 11. luvmyxr6t 12. ZeForce (maybe)
  7. ZeForce
    Pbr Calipers
    If I had a sample bracket I could draw it up in CAD and have it CNC cut from steel, but I think it might just be easier to get a set of FPV GT brakes
  8. ZeForce
    Pbr Calipers
    Do you have a link for the kit you purchased? or remember the sellers name? Thanks
  9. ZeForce
    Pbr Calipers
    Does anyone know if the 330mm rotor with fit under factory 17" rims?
  10. ZeForce
    Pbr Calipers
    So you havent had any dramas using a 330mm x 28mm rotor with the standard caliper + adaptor bracket? Im looking into this kit atm.... 330 mm SLOTTED ROTOR & BRACKET FORD AU2 3 XR6 XR8 XR6T - eBay Other Brakes, Brakes, Car Parts, Accessories, Cars, Bikes, Boats. (end time 08-Feb-10 22:34:18 AEDST)
  11. ZeForce
    Pbr Calipers
    Do BA Premo/FPV PBR C6 style front calipers require some sort of mounting bracket to bolt onto a BA with 325mm rotor or do they bolt straight up using same mounting points as the standard caliper? Im looking at these calipers KORE3 Industries LLC: On and Off-Road Performance Automotive Components which I saw in an old thread on these forums, does anyone know if these calipers are identical to the BA premo/FPV calipers? Also, is the standard brake line compatible with the C6 caliper? Thanks
