Chris xr6
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    Shire
1,163 profile views
  1. Check your swaybar linkage hasn't broken
  2. The throttle body is before the injectors therefore fuel will never get near it to clean it. the grime isan oily residue which comes from the crankcase venilation port.
  3. Im not a car dealer but that is deadsh*t comment and attitude to have, honestly welcome to commercial reality.
  4. Are you going to resuse that block form the looks of the photo you could get away with a sleeve in the bore.
  5. Chris xr6
    Bov's
    Is your car heavily modded? if not the standard bosch blow off valve will be all you will need
  6. The higher heat burns all the carbon of the valves etc....
  7. The move to v6 will also be because ford will be able to better package the front end of the car and aim for a higher NCAP safety rating. The euro 4 emmisions targets they could easily get with the current engine with a better intake setup and the addition of direct injection
  8. You thought wrong, larger diameter discs offer a higher torque value for you brake system while allowing you to more easily modulate your braking force
  9. http://eastbound.ytmnd.com/
  10. The new shape really looks like a au/ba hybrid
  11. I just hold a wrapped up towel over the front of the fog lamp to cushion it slightly and kinda punch the light inwards
  12. How did you know it's your slave oil from the bottom of the gearbox could also be from your rear main seal
  13. I hope you used stalube on the slides anything else will melt and you will be in the same boat in months
  14. Chris xr6
    Broke My T
    Yeah it sounds like a vaccum leak
