Covesy
  1. hi Guys, would anyone know the way to adjust the idle thrugh the X3? cheers
  2. Hi guys Does anyone know who stocks Turbosmart BOV in Melbourne? Thanks
  3. thanks guys, so if I go the 8psi will it be ok withh the higher end mods or do you think I will need to be upgraded later on will the 12psi be ok with higher end mods also thanks
  4. Hi guys What actuator should I be getting in a bf f6? The mods are full exhaust, turbo flapper mod, ubp, 60lb injectors, fuel pump My tuner is recommending a 8lb but I'm not sure. Advise please
  5. Thanks I'll be putting on tonight then
  6. Hi guys Just a quick question would I need a tune if I fit a under battery pipe on a bf f6 Thanks
  7. Hi Guys, just wondering if once doing a turbo flapper mod and actuator do I need a tune urgently?
  8. Yeah I'm aware about the 4 inch but just be cautious about getting the 3.5 inch when intact it's a 3 inch
  9. X-Force if ya have a look at the 3.5 external gate one where it connects to the cat it flairs out slightly to 3.5 inch the actual pipe is 3 inch dont know if the link works though
  10. Hi guys I went to pick up my 3.5" xforce dump pipe today and noticed that the actual pipe is 3" with a 3.5" flare and flange at the cat end. Looking at the pics from xforce it seams to be right. Am I getting stooged or is this right? It seams a little misleading in my opinion
  11. Covesy
    Actuator
    Hi Guys, Is there a difference between the f6 actuator and the xr6t?
  12. Hi guys, anyone have a ba/bf ego with dark agents? wanting to know what they look like before I put them on my bf f6 pics would be nice or anyone want to trade with cash diff thanks heaps guys
  13. Why would you need a 4" pipe with the gate closed. That's all the reason why I think the 3.5" would be better
  14. See there ya go 2 guys with diff opinions I reccon the 3.5 split would have the same if not more volume than the 4 anyway correct me if im wrong
