Hi All! I own a BF mk2 2009 XR6 Turbo auto. Recently I went to track day, and spent all day just doing laps around Wakefield track. About 4 hours later, I noticed my car wasn't hitting as hard as it normally does, I looked down at the dashboard and the D for drive was flashing on and off, I tipped it over to tip tronic and it was stuck and locked in 3rd. I took it immediately off track and it went back to normal with the D not flickering and able to change gears again. But now a days I drive to and from work, not thrashing it at all and about 10-30 minutes (varies a lot) into the drive the car with flash the handbrake, the traction control and the ABS on and then it will lock itself in either 3rd/5th gear depending on the speed at which I'm traveling at the time. Also little things will be effected such as reverse lights and sensors do not work when its locked, the lights on the ICC will dimmer and brighten whenever, my HID lights will flicker on and off to its own dance (left right both) and obvious its not in the right gear so taking off from 5th you can imagine is insanely frustrating. Every time I turn off the car and restart it ALL problems go away, but sure enough after a bit of driving the same thing will kick back in. I assume it's kicking in to LIMP MODE?? but you can assume right I'm still a newbie at all this so any help/advice will help A LOT what should I do??? Is there something I'm missing??? PLEASE HELP CHEERS
