tufgia
  1. What kind of power figures have people put through the t5z?
  2. How hard would it be to put a hsv t56 behind a xr6 turbo motor?? have one sitting in the shed
  3. Hey mate its at a pause at the moment trying to see if I can get my Late model camira ready for the autosalon. Then im gonna steal my girl friends ef and spool it put my t5 in it and take it out to winton and see how I go drifting before I make the xf a full house drift car. it should be done within the next 5 to 6 months! no rush atm but really am keen to drive it.
  4. THanks mate
  5. Can a auto ecu run my motor with a top loader fitted!
  6. It is going into the xf, the reason I have chosen a top loader is the fact that you can run a sequential shifter kit on them, were the t5 doesnt have a kit, and the kit developed for the t56 destroyed the syncros so they didnt produce them.
  7. Hey guys I wanna put a top loader behind my xr6 turbo engine, just wanted to know what parts and where I could get parts and get custom stuff made that I need to do the conversion ?? Cheers
  8. Would love to put a decent piston and rod set in it, but really cant afford to atm, I will be pulling it back out and put in a decent set as soon as funds allow. Got the rods realy cheap so thought it was worth while for now. Its the factory turbo.
  9. Plans for the motor arent to much, 60lb siemens injectors Bigger intercooler f6 typhoon rods valve springs stage 2 cams still tossing up between standard ecu with the x3 flash tuner, or a wolf 3d. Dont know what gearbox im gonna use yet. Will post all progress up!
  10. Thanks for the comments guys will definetly keep ya's posted as the project goes, not much rust in it there was a little around the rear window and a bit in the quater nothing to hard!
  11. Yer has a solid rear end, um wieghts around 1300, hoping for around 1150kg.
  12. Hey guys my name is matt, and this is my 1986 xf ghia, its being built for a bit of everything, drag drift, and track work. I have obtained a xr6 turbo engine for it, witch over the next month should be installed into the car. The motor and gear I have so far:
  13. So you reckon my motor with these rods I should be comfortable at 340rwkw
  14. Hey guys I am currently building an xf drift car that will be powered by a xr6 turbo engine, I'm currently trying to figure out what ecu to use, I can pick up a wolf 3d with hand controller for prettycheap, just wanted to know if any one was using one or if any one new of if it can run with this motor fine.
  15. Hey guys I was just wondering are ba f6 typhoon rods any stronger than ba xr6 turbo rods?
