mickgibbo
Good question. I will check the RPM's on my car, the XR6's at work and my fathers G6E Turbo and see where they idle. I'd like to think the mechanics at Ford would have looked at that.
Good Morning, I have had Ford look at the noise and they replaced a muffler under the glove box. This got rid of the noise, however the cause of the noise is still there, the car vibrates at approx. 500 or 550rpm. This has highlighted other smaller noises. I have also had people comment on this when in the car. I will clean the car out soon (so Ford cant blame the pen in the glove box etc) and take it back. Long and short, they fixed the noise but not the cause. Could this be a tunning issue. Regards
Hey, I have the same problem with my May 2009 FG XR6 Ute with 75,000km on the clock. It sounds strong when idleing in 'D' and not in park although the revs are similar. I had it at Ford last week for the 75k service and they said they couldn't find it, however they "tightened the exhaust". Since then it has been louder. The service manager said if it continues, don't hesitate to bring in back in, which I am doing tomorrow. From my lack of car knowledge and listening to where it is comming from, it could be a broken baffel which only vibrate at the correct RPM. I will let you know how I go. Regards, Michael.
Hey All, My father went for a trip through country VIC, NSW and SA recently and on return the front of the car had a couple of bugs hanging on. The bugs came off the paint work without to much of an issue and the radiator/AC condenser cover was removed to clean them and they came up reasonably. The problem lays with cleaning the intercooler, we cant get to it to clean it. Can anyone explain how to remove the lower grill on the G6ET. I have attached a couple of photos FYI. Thank you in advance. Mick
I have the same problem on fast pumps the way I get around it is to turn the trigger 180degree to point up this solves the issue. I had a similar thing on a Hilux which had to be tilted 90degrees I dont really watch the fuel gauge on it but monitor the range, trip and avg L/100km on a long trip I get about 750km/tank and put about 75-80L in and that's running it to a range of 0 with highway (not freeway) driving. Run it down do almost 0 a couple of time and see how much petrol up put in 81L tank and a couple in the line. Hope this help
Tab is correct , Ford classify the front door speakers (2ways) as 2 speaker each. This is the same as the G6ET where there is two missing when talkin to for they say there is two in the front door. This has been mentioned in other forums. I installed Dynamat on the back wall after about 3000 km and I believe it reduced road noise slightly but made the stero sound alot better. Mick.
Hey, About a month ago someone ran up the back of the ute and put a hole in the rear bumper near the number plate. The driver stopped gave me his details and a week later I had a quote to fix it from a recommended repairer and received the money off the bloke the next day. So I booked the car in and took it in to get fixed last week. When I got it back it had a run in the clear coat near the number plate. Today I took it in and they "just cut it out". When I got home a noticed enough run in the clear coat behind the tail gate hinge. Its hard to show in a photo but attached is a photo. Im not sure if they would do more damage trying to remove the run and it is kinda hard to see. Does anyone know what the panel beater would do to rectify this? Thanks Mick Gibbo
that's a good price! was it the Hayman reece type (removable tounge)? and was it heave ute or light duty?
I also have an 09 ute and although I get reception around the main areas it doesn't take much to loose the reception. The Pioneer radio in my old ute was def better.
Some of the guys at work use big entry mats with the rubber backing which they love, but others use the thick 10mm rubber mat with holes which does an amazing job at stopping things sliding. I was thinking about a rubber mat but the adjustable dividers are working well for me.
I to would like to know the cost of a heavy duty tow bar for FG S/S I had a toyota genuine light duty put on a tray back ute about a year ago for just under $500
I have only owned utes I have driven different utes at work but I don't drive a ute because they give me a good ride or because they are a drivers car. I drive utes because they are what I need, I cant throw stuff in the back of a wagon or sedan and not care, and I cant carry bricks timber or tools in wagon or sedan without doing some damage. And the same goes for why I don't drive a Expensive Daewoo ute. Apart from Hay Bails and empty cardboard boxs a Expensive Daewoo ute (higher omega) can't carry any thing a wagon or sedan can't, throw a hard cover on and chances are you will have to take the hay out. So I don't understand why someone would buy a Expensive Daewoo ute and brag that they ride better. And to that I ask, how many vehicles are there in the Ford range which can carry the same as a Expensive Daewoo Ute (jack all) that would have much better ride and handling? Why do people who care about ride and handling buy a ute when they don't intend to use the rear?
Made the rear divider this afternoon. I got routered a 14mm wide by 10mm deep slot near the centre of the board to line up with the slots in the tub. Im going to make a 350mm wide by 200mm high divider to slide into the slot to stop stuff rolling around. I intend to make two slots in the divider the near the cab to make 3 partitions to fit a couple of plastic tubs for ropes etc.
I have to say Dash (Metallic Green) does a very good job at hiding the dust, just as good if not better then my white ute and better then black.
