darios typhoon
Everything posted by darios typhoon
  1. thanks brain it will be better next time for shore but wheel spin was a big problem I didnt think it would run a 10 with that much wheel spin so I didnt get of that much at the top. one run isnt enough pressure was at 12psi I was dropping it to 10 psi on next run but no chance, 60 foot was 1.701 1/2 track was 105..97mph 7.0 sec and 1000ft 9.07 sec and the 1/4 10.76 @134.44 .
  2. launching the car manual mode put it in first gear as lights are going down push throttle down about half the rear will squart watch boost about 5 psi it will be green pretty quick then push right down on throttle then take your left foot off the brake as you are putting your foot down yes I uesd manual mode all the way.
  3. no its a full street car but ill be going again but may be on full slicks to get a good time with power and sh*t track you need the best tyres
  4. sh*t track to much wheel spin but 10.7 with spinning first three gears and one run and kicked off.
  5. how did you go with your car on dyno
  6. thanks ill do that when I run new motor you been very helpful thanks. aslo im running hoosier street radial.
  7. I am listerning. typhoon has bigger brakes and the 17 inch wheels just fit over with a bit of grinding on rear caliper. do they do a 28 tall in a 17 inch rim.
  8. there is heaps of torque but the street radials that im using are suppose to be very good. I need to change all the rear break set up because its to big to fit 15 or 16 inch rims and then taller springs to get those 28 s under
  9. thanks for all that info ill run it with the 26 s for now and when we build the new motor ill put the 28s on .
  10. thanks for that the brakes on the rear of typhoon are larger than xr6 turbo 15 inch wheel I would need the xr6 rear brakes is that right .and taller springs. the gaurds are liped already so what other mods do I need.
  11. hi just wanted know what power did you run when you ran the 10.5 at 135
  12. are you running pump fuel first and then race fuel
  13. hi matt have you dynoed your car yet
  14. what is the biggest size slick can you run on a sedan bf model with out scrubbing
  15. ace do you know which cars are doing that thanks.
  16. penrite syn atf is the sh*t and cheap just like standard oil but cheaper
  17. I'm pushing 482kw on 98 but race fuel next week and ill see well over 500 kw the gearbox is built by dominellos so its alot stronger than stock
  18. any one running over 500kw with there zf 6 speed
  19. matt ive pushed 500kw through it so far and going on race fuel next week.but not pushing it all the way as its still stock bottom end one more thing those weaponx coils where did you get those
  20. hi matt just wanted to know how much power are you putting through your zf6 speed
  21. *Beep* there are alot of pump fuels 98 ron 100 ron and e85 ethenol
  22. What's on your mind?
    1. tray_182005
      tray_182005
      that's good mate cant wait to see what it makes
  23. ive got 450kw daily driver dominello transmissions did mine . and it works great he is in sydney. dural. upgrades clutches and does valve body mod and also converter which is fantastic stall is around 2800 rpm but drives like a standard one.
  24. get tune house to tune it and you'll get more and it will be as smooth as silk and come on boost better .and he will let you know what you can do with your budget.
  25. the valve springs where stock and ran 20 psi at the top end to make 450 kw atw now it has nizpro ones but changing them to race atomic series the bottom end is stock and have pushed it to 500kw @the wheels with race fuel.and the bottom end is still fine.
