darios typhoon
Everything posted by darios typhoon
  1. it made 450kw
  2. that customer was me on diiferent set up and it was 540kw and on dd dyno was 500kw with 20 psi in tyres
  3. hi guys jim from tune house has got 500kw on stock manifold and standard turbo using e85 on my car so it can be done that was on 24 psi
  4. you just love to stir sh*t
  5. no 38 offset max taleb have the right wheels 44offset is to far in
  6. taleb tyres near tempe you can get d1r lenso wheels about 250 each rim and they are light.
  7. those porsche tyres are for circuit they wont work 17 x 9 275 /40/ 17 will do the job and fit over the brakes youll need 35 offset rim so you dont scrape not 7or 8 inch rims not enough tyres contact get mickey et streets the ones with least amount of grooves in them.then you can launch alot harder but do a decent burn out.
  8. ive got the same converter it perfect when you take it to the track are you hitting limiter if your spinning that much your foot cant be flat the hole time so your mph wont be up !get some real tyres mickey thompsons or hoosiers then youll be able to run some good times those normal street tyres are sh*t for power over 300kw at the wheels so dont bother with the bridgestones
  9. powerside there is a 5% difference in power figures between dynos but its also how you drive to get a good time at the track you have to do every thing right 12s is slow all the other guys that have tunes from tune house around that power have run 11s even my self I ran 11.04 with 450kw @ 130mph with a slipping box. so get tony to check your car out there might be a problem.
  10. new motor should be about 3 weeks but then have to wait for jim to come back from holidays then push it a liitle harder. may be 700kw
  11. the turbo is???????????????????????????????????????????????????????????? its like a 35r but a fair bit better and not tz04 core. when I run it again at the track ill let you know what it is .
  12. the power it made was a top effort especially from a standard motor. soon to be upped to about 700kw with the new built motor so jim can push it to the limit of this little turbo.not a dyno queen turbo.good street turbo it comes on very early and like a bulllet. its insane. the 600kw it made was to see how much the stock bootom end could take .and that it .
  13. jimmy im one of jims customers darios typhoon I have the typhoon with big power as well and im selling car and you where saying that you are looking for one that's done.
  14. thanks spiko it is the only way to get down the track safely front runners and the right suspension set up. mine was not right .not enough travel in the rear.
  15. yes I made it there to the drags but no traction at all had five goes but wheel spinning to limiter all three gears plus those tyres didnt work they behaved like a slick wobbling real bad down the track couldnt even run to half track with out it trying to put me in the wall or over the line it was very dangerous to drive . andra officials said I couldnt run any more because to dangerous the car was better with the other tryes and suspension set up it may have been alot better with front runners but I dont like the angle of axles becauce the wheels are to high and the cvs will fall apart due to being not horizontal .
  16. thanks spiko hopefully nothing breaks as well !! all standard rear end as well.
  17. hoping to get real low 10s
  18. modified zf 6 speed with a 3000 stall done by dominellos
  19. the fuel is e85 the exhaust is working great. matty its a bf mk11
  20. thanks trav hopfully no rain wednesday ive put 28 inch street radials on today should get some grip this time.
  21. last night put it back on dyno and jim hit the big 600 kw @ 25 psi and still stock internals but that's all its going to get with that engine take to the track one more time and see what I can get.
  22. great effort john at least you got heaps of runs to get it down .try my street tyres they will get your 10 that you are after.
  23. that's awsome power nice gtx ????? GOOD WORK GUYS is that car going down the strip. it would be good to see .concrats.
  24. thanks spiko for all your input its been helpfull. I'll be doing that next time out for shore and improve on that number with no doubt. ill try one more time on street radials then move to slicks.
  25. adding to your launch question depends on your turbo size and converter stall bigger turbo you will need to push more throttle to get more boost on the start line to much of the line and you will break something or wheel spin to much. but you'll need practice to get it right.
