Hendrik
  1. What car will you be in? ill keep a look out for you
  2. I should be down there again tonight, ill be in a yellow bf, come say hi cheers Hendrik
  3. I was the yellow BF XR6T with out the sunroof, I was the secound last person to drag before the stoped it, I thought that they canned the burn outs aswell so I left early. Ill see you down there next time
  4. saw alot of flacons down there last night, but didnt meet anyone from this forum I endedup getting 3 runs in before the rain started to come down, my best run was a 13.200s but I had a 60ft time of 2.4s so when I put some new tyres on I can hopefully get into the 12s
  5. whos going down this wednesday? if its dry this will be my first time down. I have a BF XR6T with 6s auto currently running about 270rwkws any tips? cheers hendrik
  6. its an electric one, I assume its connected because it lights up and it shows a constant reading of about 30 psi
  7. when I baught my BF XR6T it came with an Autometer Cobalt Boost/Vaccume and oil pressure gauges fitted. the boost gauge works fine, however the oil pressure gauge doesnt seem to be working at all. it just sits inbetween 25 and 50 psi and doesnt move even when the car is switched off. any suggestions? this is the particular gauge http://www.egauges.com/vdo_ind.asp?Type=El...amp;PN=ATM-6127 cheers hendrik
  8. how do I test the sender unit?
  9. I dont think my oil pressure gauge is working properly. or at all. it seems to stay around 28psi no mater what even when the car is turned off. any ideas cheers hendrik
