Justa6
Everything posted by Justa6
  1. It's a c4. Yep single cammer au.
  2. Ah, sorry . I thought you ment me.
  3. I would if it had one. Yeah no log just a dyno run. I'm not saying they are the best cooler by a long shot. Just people get all wrapped up in big rwkw numbers and big brand names. Cheap coolers on a well setup car can produce good numbers as well.
  4. Get tapatalk. Heaps easy to upload pics.
  5. And that's on a single cam, so you guys should double that haha. Doesn't actually show IT.
  6. I've got 480rwkw on a rapid cooler, seems fine.
  7. What about nt05r? Aren't they almost as good as et's, and well priced.
  8. I use it all the time on multiple forums and find it really good.
  9. Gee those brakes will be insane. As for girdle, I would of thought with the power you have , you would already have one. Would definitely be a good idea.
  10. I think you'll find 19" being a big part of the problem.
  11. Total mechanical in lismore, Zac speed alstonville. Generally just go up the coast though.
  12. Well done. Great 60 as well. Hooked up no problems.
  13. 55psi in the tyres. Wow . What size wheels.
  14. Mine just started working again on it's own.
  15. When I log in on tapatalk, it usually says 20 unread or something. Now it just says 0 new topics. Any ideas why?
  16. Impressive. Well done.
  17. I've widened 15" steel wheels no problems. Alloy is a a bit harder, you need 4 wheels to make 2, so there is only 1 weld . How much power have you got? A lot of guys running 10's on 17". Just have to bolt them on.
  18. Standard 17" xr6 ba wheels are the go, with a 275 45 17 et.
  19. I think the reason you have a 16 is because a 15 won't fit over ba brakes. I have au rear brakes.
  20. I put a 235/60/15 et street on standard ford 6" chaser. Fit pretty well, unreal traction.
  21. I've got a rapidsystems cooler. Tuner said it was working well on 480rwkw. Was cheap enough.
  22. That fg is horn.
  23. I'm looking at widening some standard 17's to 10 or 10.5" and maybe putting a 315 under it. I think it will take some adjustments to the inner tray tub.
  24. not using washers can cause the nut to grip into the alloy and give a false torque reading. I went 115 on mine.
  25. Well you give a car to some dumb f*ck, who has no respect for other people's things and it'll break.
