Justa6
65 Excellent
  1. Usually you do a spiral type pattern outwards, more important when doing them up. I haven't built a twin cam, but sohc I went 115 on the studs and it's around 40 on the cam caps.
  2. Top work. Keen to see how it goes.
  3. That's good buying. I bought exactly the same radiator $340. Works well so far. Although I got thermos as well.
  4. That's good buying. I bought exactly the same radiator $340. Works well so far. Although I got thermos as well.
  5. Ah OK, mine are welded on the inside. So rubbing is minimal. Keen to see how they go.
  6. The caltracs are always going to rub a little, I doubt it would get much worse though. Do the links go in exactly the same spot as where the leaf was?
  7. Seen a few of these now. Look good on the road.
  8. Is the forum still tapatalk compatible? I got the latest version of tapatalk and can't seem to find the forum.
  9. Justa6
    Fg 565Kw
    This just had another run on the dyno before powercruise. Still pushed out 750 something hp standard engine with pump gears and head studs.
  10. Supercharger. You'd be surprised how much you can spend NA to get such little power. A dude on aff was doing a very well priced pd blower set up. That's the way I'd be going. http://www.fordforums.com.au/showthread.php?t=11392659
  11. Man the back of them are ugly. What's worse, is I come on here and this is the most active thread.
  12. The car was at Graham Harris butt plug. I'm sure he knows what he is doing. He said with the gearbox and turbo combination on this car it's an absolute animal.
  13. Bit of a thread mine. Probably seen it elsewhere. And broke the straps on that run.
