dayjunkie
1 Neutral
About dayjunkie
  • Birthday 26/06/1980
    QLD
1,694 profile views
  1. both I removed and cleaned up appeared identical and identical ohms from memory
  2. pretty close mate few mm out do you know if this spring on the chain tensioner could contribute to the 'cam positon timeing over re-tard faults ' I get. this fault P1383 , P1388, recurring faults sometimes on idle , sometimes the moement I start it, and other times it seems when the car warms up with 20kms driving. It cuts power back and if ya up it feels like its surging and gutless, I have to reset the faults with the X2 each time. The only thing left to check is the fuel circuit.
  3. seems timing is ok l
  4. thanks mate, not sure how this is possible but my sprokets in that position are 180 degrees out to the the yellow links. Sprokets in that position match balancer alignment though. I had billet chain , pump gears, replaced 8 years ago so its possible that mechanic measured time from another angle. Another crack it tomoz probably got another rotation left to spanner around...
  5. Any tips on turning the harmonic balancer by hand to see if the timing chain matches up,or is it as straight forward as I that
  6. 2013, wow , I have been neglecting this girl.
  7. Thanks mate, pickin up a gasket now, im hoping solenoids unbolt and slide in and out without any complications. Hope its not a chain, heard gotta drop engine to do, might be time to get another bank loan and put Atomic Short engine in.
  8. The cam assembly would be a real hassel to remove, I just want to make certain the solenoids arent stickin or clogged, its 1 of the last checks to solve my ongoing intermittent 'Cam position Timing over-retard fault'.
  9. I overheard some ladies at bingo saying the ZF6 tunes are now apparently too large to store on the capa SCT X2 Flashy box??? Anyone else heard this SCT cash grab because the champion that tunes my car hasnt, and he said he can just put the tune in the car and forget about the flashy if SCT gona play tight fisty coonts.
  10. Hey T junkies, Anyone know if I can remove the 2 cam timing solenoids for cleany just by removing rocker cover and without removing the entire cam assembly,,,because that would really suck.
  11. Happy Birthday dayjunkie!
  12. Happy Birthday dayjunkie!
  13. Happy Birthday dayjunkie!
