fehlbie
21 Excellent
About fehlbie
  1. Well, it is my NEW play thing...
  2. Cost me $200 for the gate mod. I removed the turbine housing and gave it too him though. It would obviously cost more if he had top remove the housing for you. I didn't take a photo of the welded internal gate. He was very thorough thou, he welded it completely and even welded up the swing arm hole. If you are interested, check out his Facebook page, it shows a lot of his handy work, he does top grade fabrication work.
  3. Just thought I would share. Gavin from Garage48 phone: 0415 475 130 did the fabrication. He welded up the internal gate and welded on the pipe for the Tial 44mm external wastegate. He did a beautiful job. If you want to see some of his other handiwork, check out his Facebook page Garage48customs.
  4. I like it. Don't know why everyone is being so negative about our last falcon ever. Who else makes a car for $45k that will hand it too a BMW m3 and haul the family in comfort. It is the end of an amazing car that has spoiled us with such performance.
  5. Falken fk452 would be a close second
  6. I have run Bridgestone, falken, Dunlop and Nitto Invo. The Nitto Invo is the best tyre I have used. They are quiet, grip really well in the wet and dry and you get reasonable mileage.
  7. You will NOT get traction with any road legal tyre, period. To much torque to the rear tyres in 1st gear.
  8. Disconnect the hose connected to your actuator. If you still reach 19psi your wastegate needs a flapper mod and a port.
  9. It is the gearbox. I have been told it is the lay shaft. It is not shimmed properly from tremac, but it is not a problem. My car has 125000km on it and no issues. It has made that noise since new.
  10. Bong
  11. You need a curved pick, a torch and a mirror. Simply hook the circlip and pull. Easier said than done.
  12. 1.06. Is what you need.
  13. Tack weld the bolt heads to the flywheel
