Out of the ones you have suggested, boost guage for one, but probably one with 20psi max. Having the 20psi just makes the scale a little bigger, and more use of the guage. The 30psi guage would be sort of like only using 2000rpm on a 8000rpm tach! The others, a oil pressure guage isn't a bad idea, but I would think that out of a stock turbo'd and limited upgrade engine, it will be of no real value. X2 for the temp guage, unless you are planning to take it to regular extended track days. For a newish tinkerer, the AFR guage would be the best other option. With it, you will be able to become familiar with what the engine fueling is actualy doing. You can see when the ECU is cutting fuel for overrun, and leaning out mixtures on lean cruse, and most importantly see the nice rich mix under load. If it is a decent (5V wideband) guage hooked up properly, you should be also able to see where the factory fueling is far too rich and that with an edit down the track, the fueling comes back more to suit max power rather than crude engine survival technique. After driving around for quite a number of years with a mixture metre on my car, I would feel blind without it. Damo
