Robos F6
Everything posted by Robos F6
  1. Well said, it was exactly what I was thinking. By the time it hits the turbo, heats up again then thru the intercooler, it would be very minimal difference. Also, where is the Cold Air feed for the drivers side air box? I dont think I have ever seen one so I assume all of the air is coming from the engine bay just like your modded xr6 box.
  2. Stock Cooler?
  3. Sounds like you have traction problems allready only getting a 11.5 with 400rwkw
  4. Ray Donovan is great
  5. You need a tune and xcal to get the most.,$1,500, add a venom cat with a few extra holes in the air box, Then you will notice a huge increase rather than a small one by going CAI
  6. Thanks mate,
  7. Stock Agents and I like to keep it that way.
  8. Can some one measure the 255/35/19 invos and ill compare against my Kumho Ku39, just need something stickier but I like the fatter look at the back.
  9. There is a NT05 255/40/19,. how would this go on the rim? I've seen the 255/35/19 Invo and they look skinny
  10. No it doesnt have the muffler delete pipe as on a FG Try the F6 snorkel on your intake
  11. Can't see why not unless your going to track it with continuous wide open throttle. Squirts here and there shouldnt be a problem. I've got 315rwkw with my standard BF F6 intercooler and havent had a problem and it still ran 11.7 on the strip. Factory ZF will handle it easy.
  12. Nice, what mods?
  13. 11 second 1/4 aint crap out of a stock cooler
  14. Won't support you 340rwkw but will get you 300rwkw easier enough and run 11 second 1/4's
  15. Same here, struggling with the mumbles but im upto date with it Im still watching The wlaking Dead, Revenge and might try House of Cards
  16. Anyone Interested in Iridiums?  Might be able to do some cheap
  17. FG - Ford XR6T 370 x 255 x 55mm = 5189 cm3 (Factory) FG - FPV F6 370 x 380 x 45mm = 6327 cm3 (Factory
  18. Ratter could probably do it in 20 minutes as he's probably done a 100 of them. 1st one is always the hardest. Mine was tricky too. Once I loosened the dump I could get to the circlip easier and then you will need to work out how to remove the circlip you will home and hosed.
  19. Anyone recommend some good TV series? I've watched Breaking Bad and currently watching The Walking Dead and loving it.
  20. I use these ones, there the same as the WRX ones http://www.ebay.com.au/itm/6-NGK-IRIDIUM-SPARK-PLUGS-BA-BF-FG-XR6T-TURBO-FPV-F6-TYPHOON-/251422706836?pt=AU_Car_Parts_Accessories&hash=item3a89f60c94
  21. Is the new XR8 going to be better than the old FPV GS which I thought wasn't much. I would still rate the F6 miles in front
  22. Nice numbers. what fuel?
  23. A guy ran 11.0 F6, E85 tune. dump pipe cat and slicks. I assume 11.3 from the GT had slicks as well
