loaded
About loaded
  • Birthday 11/12/1968
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    sydney
  • Interests
    motor cars,snooker,soccer and going for cruises
  1. Happy Birthday loaded!
  2. Happy Birthday loaded!
  3. Happy Birthday loaded!
  4. Happy Birthday mattyc90!
  5. Happy Birthday Lazar!
  6. Happy Birthday Robotnik!
  7. Happy Birthday Markwr400426!
  8. Happy Birthday loaded!
  9. Happy Birthday Robotnik!
  10. Happy Birthday Markwr400426!
  11. Happy Birthday loaded!
  12. Thanks,I will get the plugs you suggest as I am confident that the idle problem is caused by the plugs. I have reflashed the factory map and the same problem with power loss is there.This suggests to me that the edit is fine and the problem is elsewhere.Still scratching my head. Peter
  13. I have done a search on intermittent power loss and an increase in fuel consumption and can't find anything that relates directly to my situation,so any advice would be appreciated. I recently bought the edit with generic tunes and found the car to be running very consistently with both the 8psi & 10psi maps.At the time of purchase it was run on the dyno to make sure all was fine and the results were safe. After a week of driving my fuel economy actually improved from an average of 15.5 l/100km to high 14's even with some spirited driving. One day I noticed that the car started behaving weird, in that one minute it would go hard and then the next it would loose considerable power.I also noticed that within a few days the fuel usage has gone up to 17.5 l/100km and still rising. I have checked all the hoses for loose clamps and even decided to fit the new intercooler which I had sitting in the garage waiting to be added with some other mods, which I intended to do all at once.this eliminated the loose clamp scenario. My spark plugs were regapped at time of edit which I noticed caused the car to pop on idle.Should I check the plugs again? Any advice as to what could be causing this and what other things I could do to try and track down the problem would be great. Thanks
  14. No offence X-Wing but if you had read the original post you would have noticed that he was having some issues with surge and bad idle.So I guess that your theory does not apply here.Good to hear you are one of the rare ones that has had no problems.
  15. Check out the Rocket Industries site.It looks like they have some valve springs on there.
