kovac
About kovac
  • Birthday 05/12/1979
Contact Methods
  • MSN
    antun_k@hotmail.com
    campbelltown
  • Interests
    cars, fishing
1,414 profile views
  1. Happy Birthday kovac!
  2. Happy Birthday kovac!
  3. Happy Birthday kovac!
  4. I get the 4 beeps after trying to start it and letting go early but what I also noticed is whilst its beeping u will c the oil light flashing aswell I know its not a big deal but it gets anoying after a while
  5. Happy Birthday kovac!
  6. Mine are replaced but I done the front and rear bushes with polly urathane but at the same time I replaced the shocks with adjustable coils the noise has stopped but the biggest thing I dont undrstand is how can you crack the tailshaft rubber housing with a stock car
  7. When I buy bearing for the car I always get them from cbc bearings never had an issue with their bearings
  8. My bf was making a similar noise I replaced the front right to find out the left bearing needed replacing aswell the bearings arnt expensive I payed $266 for the bearings and if your doing it urself ull need either a "1 1/2 or a 32 m socket and it is easy to replace
  9. I was also amazed that you didnt need to service the zf but from what I have fiund out is that it is also picky in how much oil is in the tranny if you either put too much or too little itll play up and the kit (plastic pan and accesories needed) will cost around $700 just for the kit from ford they said you only need to get it serviced when u have probs with them
  10. Slightly stiffer and when u go in a pot hole the car doesnt feel like it shifts u dont really notice it
  11. I had the same thing up untill about a week ago I replaced all the bushes front and rear ( poly urothane) and also changed adjustable coilover shocks and upper/ lower ball joints and the noise stopped I was told that its caused by the std bushes from ford that its not designed for the turbo models as it is to soft the whole set up cost me $3100
  12. This may sound like a noob but I was told that u can get a zf 6sp rebuilt with ceramic gears which hold more torque for $10,000 it doesnt sound right to me but has anyone else heard this
  13. I payef 1500 for the coil overs 500 fitted
  14. I am currently getting tein adjustable coil overs for 2000 fitted they are costing me 1500
  15. Mine does it aswell and I found that my tranny mounts were cracked and the tailshaft bush was shagged ford said that this could b thr fault ill find out when I replace it in about 3 weeks time
