VippiN
Everything posted by VippiN
  1. Hey guys sorry for the bump. I also prefer the look from gu4800 & velociTy's car standard springs on 19s wheels. Mine is a ute so I like it to look a bit more functional than low. I'm currently changing my suspension and springs, I have bought King KFFS-53 springs which is standard XR height but I've heard on the grapevine that in the King Spring series it's the Lows that are XR height.. Anyone heard anything like that?
  2. Alright, thanks for that. Not sure if anyone would know, but if I install standard King spring replacements would I sit the same eyebrow height? My eyebrow height is approx 360mm right now at the front on 19" wheels / 245/35 tyres.
  3. Hi guys, I'm replacing my shocks and want to know if springs from a BA XR6 will fit in a BF Mk2 shock. I'm a little worried about changing to a new spring as it currently sits perfect and don't want the eyebrow height to change at all. I can only assume the current BA spring is standard.
  4. Hey mate, give Damien from Main North Automatics & Driveline a call. They work on ZF's a tonne.
  5. Perhaps it's your exhaust metal expanding under heat?
  6. Fair enough - They could've said that over the phone though I'm happy to order a replacement part if you can post it to Adelaide, as long as it's the same one on the original invoice from quite a few years ago now
  7. Yeah I did think of that, but a lot aren't branded so might be up the creek for that effort. I need to drop the coolant anyway and would much prefer to do the lot in one shot. I've heard that before as well, but I'm happy with how it is/was, I just want the same thing I had. It's like if the turbo blew, I'd just get a direct replacement.
  8. The invoice reads "Supply & Fit Low Temp Hi Flow Thermostat" $27.27+GST I was a bit disappointed when calling, as regardless of what type it was the answer was "We buy them bulk from Repco, we don't know what brand they are." I'd still like to get the exact same thermostat, as it's had no issues before and I just want to get the same product to replace the current one.
  9. Hi guys. My car uses a high flow thermostat that was put in by Pit lane performance, I reckon it's a bit dodgy so want to replace it with the same thing, called Pit lane and they say they just order them in bulk from Repco and don't know the brand. Called Repco, they only do one type, just a normal flow not a high flow. My temp has always sat exactly on 1/4 - Can someone recommend which hi-flow to get and where? Thanks!
  10. Hi guys, have a bit of a weird problem. Picture this: Going for a normal drive, mostly off boost. Some on boost. Get to destination. Turn off car. Get back in car after few minutes turn on car - Temp has gone from where it sits normally at 1/4 to bit over 1/2 way. Turn car on, fans kick in, heat drops back down. This is what's been happening last few weeks. After a hard boost session, temp actually hit 3/4 when going back to the car. Letting it idle for a few minutes before turning car off has little to no effect. Thoughts? Ideas?
  11. Hory sheet. Glad I haven't had to pull apart my interior yet. Doing it on a Ford Laser is a bit easier! Have the whole interior out in about 10 minutes lol
  12. I had the same fluctuating rpm after my trans cooler was installed. Turned out the people that did it didn't top the oil back up. After it drank about 800ml of life guard it's been fine every since, even when stone cold in the morning at 3c.
  13. VippiN
    New G6Et
    If you don't want a loud exhaust you don't need one for 300 - I'm still on the stocker with 323kw
  14. You're in Adelaide, I went here if that helps - https://www.facebook.com/mnautos?fref=ts
  15. I didn't have a whine but I did have an issue with my cruise control rpm fluctuating. Only start happening after my trans cooler install. Took the car to my local trans specialist and it drank 700-800ml of life guard. No more issues after that - So it shows how sensitive they are when not full.
  16. I've never seen a ute with the BF update skirts so I'm guessing they never came out with them. Has anyone seen or know of somewhere that does them for the ute?
  17. VippiN
    ute register
    Hey guys, this is my work commute, what a great buy she turned out to be. Have wanted a ute for nearly a decade and bought this one early in the year. Have spent a bit of cash on her now and she performs as good as she looks.
  18. Pretty much as title. Which is recommended?
  19. I have just moved from 245 KU31s to 275 Invos. I believe I have a 80% traction improvement - Yes it will still spin. But the spin is much more controllable and much harder to initiate with flat footing. That's what I found too!
  20. Hi guys, slightly annoying problem with cruise control, when sitting at 80kmph it will hunt from about 1300rpm to 1500rpm. It doesn't like 1300rpm much and will get a slight vibration as it jumps back up to 1500rpm. Is this a common problem, the tune, something I can fix etc? Thanks!
  21. Hey guys. I have limited shed space and want to rock the open tray look for a while. I'd like to store the hardlid vertically against a wood wall but don't think the locking brackets or hardlid hinges are really good enough to hang them on. I was thinking sitting it on some foam, but worried it might damage it.. Any ideas?
  22. Sorry for the revive, but does anyone have better pictures of the hinge/brace? I am going to get one custom fabricated, just need better pictures. Once I get it done I can post back with results and prices for anyone else who wants one.
  23. Anyone got an idea where I can get an F6 center console lid with the white stitching? Been ringing around wreckers and even the expensive as sh*t ascot ford wreckers dont have any.
  24. I recently bought a ute. Glad I did. Out of all the sedans I've had I think I had people in the back like 10 times in 10 years. However I've always thrown gear in the back seat. Not to mention having a ute is just tough. Must admit though, the bum end bounces more than a sedan would and traction is non existant (speaking of which my semi's are in the country now, yay) As far as the ute handling worse than the sedan - Who is buying a Falcon for handling lol.
  25. I had a similar issue and ended up being the place I normally get wheel alignments was crap, went somewhere else and they did the job properly
