NYT-SKY
Everything posted by NYT-SKY
  1. [quote name='Jake27' post='802247' date='Jan 13 2009, 10:56 PM']Headlight kit is in :D 4300K's[/quote] Looks the goods. But looking at the second vid it looks like the headlights need to be adjusted a little. Congrats.
  2. Your cheapest and best bet would be these: I have had led brake lights in most of my cars, these semm to work well on most cars.I think the BFs would benefit more than the BAs due to their clear light lenses.
  3. Check your mailbox mate, sometimes if noone is home to receive a delivery they normally put a note in the mailbox for you to fill out, so the driver knows where to put the item in the next days delivery.
  4. [quote name='Russ F6' post='800157' date='Jan 10 2009, 11:09 PM']Well I finally got around to installing my HID's tonight and wow do they make a difference. Had a little trouble with the metal clip that holds the lamp on, besides that everything was easy. Well worth the dollars. Russ[/quote] Due to the thickness of the rubber base, the metal clip requires a little more force to hook into place. But its the same with any HID kit.
  5. I know, i know He told me the other day. Im definitely in for the next one.
  6. My car is alot more fun to drive than a ZF auto though
  7. There is the magic word...AUTO Auto XRTs are very quick.
  8. No unfortunately. Specs: All factory dags cleaned up in the head New OEM valves New OEM bronze guide TOMEI valve springs HKS 256IN 264EX camshafts HKS cam gear Custom head to sump oil drain GATES racing timing belt SPLITFIRE coilpacks COMETIC headgasket MAHLE pistons SPOOL rods JUN crank collar ACL race main and rod bearings ARP head stud ARP main studs ARP exhaust manifold studs Greddy plenum N1 oil pump N1 water pump NISMO 740cc injectors NISMO fuel pump NISMO engine mounts 6BOOST manifold (coated) GT3076 .82 (wategate off the turbo housing and coated) Synchronic 50mm gate Custom exhaust/screamer 4 inch intake Cooler ECT ECT All controlled via HALTECH E11V2
  9. 1st time out on old setup. 13.0@113mph chinese tyres and slow changes into 3rd (worn synchro) Hoping for high 11s.
  10. On my old setup of 250rwkw I was beating XrT with 100rwkw more. With 4.11 diff gears standard it was no contest off the line, I would be in second gear and a car length infront while the XR was still in first. Skyline 1400kg XRT 1800-1900kg On the freeway was a different matter. The torque of the 4L would be very hard to beat. With current setup I have yet to make a comparison, I would think an XRT would need 400+rwkw to keep up.
  11. There will only be a slight gain. If you can get the Competition (4480) I think they are then it will be better. But then again the outcome will only be in the region of 10-15kw or so. A good exhaust mod none the less.
  12. I have forever used Shell 98, BP Ultimate and Vortex. In the next few weeks when the new engine is run in ill be getting the engine tuned on E85, its like race fuel on pump!
  13. Have always used Motul in my engine. Changed to Edge once to try it out. Made the engine noisy too. Now using Motul Chrono 300V Edge is a grade 3&4 blend Motul 300V is a Grade 4&5 blend There is a reason why its at the cheaper end of the "performance based" oils.
  14. If you have the right colour temp ie: 4300k-5000k and you adjust your headlights properly, you wont have a problem from the police. Ive had HIDs for years and never had a problem. There is a HID group buy running at the moment, check out the thread for more info.
  15. Has anyone bought a 6000k HID kit yet? If so can you please upload some good pics of them in the car and working?
  16. I think you mean the panels used for the floating roofs. The ones suspended from the real roof, makes the roof lower to conserve on heating and cooling bills. And no I do not know what they are called.
  17. What ever happened to KEN24T? I used to do Kung Fu with him many moons ago lol
  18. Are you saying you get pulled up if you talk on a subject too long? Seems a bit harsh to me. Im sorry sarcasm does not get portrayed well in a forum lol
  19. New thread: So what is the reason you are not driving your car at the moment? lol
  20. :oohwoah: Mine should be on the road late Jan I hope. I always set a date but it hardly happens lol
