SLider
About SLider
  • Birthday 19/08/1988
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    Perth
  1. Happy Birthday SLider!
  2. Happy Birthday SLider!
  3. Happy Birthday SLider!
  4. Happy Birthday SLider!
  5. Nah its a BA mk2 with premium sound so I don't know if anything will be different for an FG
  6. Mate it rides beautifully, so much better than standard you wont regret it!!
  7. I installed this combination yesterday, Initial thoughts are its a great combo if anything could go a bit stiffer if you were racing it regularly but you would have a distinct lack of ride comfort on the street. It took me awhile to install them but I was doing other things at the same time so it could be shortened considerably from the six hours it took me haha it didn't help it was raining as well. I am getting a wheel alignment in the morning to make sure its all good then I will take it for a proper drive to do a proper test. Cheers, Tim
  8. Have you asked tempe whether they will actually supply them to you yet because I was looking at getting the same rims not that long ago and I asked about them and they said to me that they are no longer supplied in fitments to fit a falcon. that was a couple of months ago now but from what they told me it sounded like they were not getting anymore in. Good luck hopefully you can get the rims you want. Cheers, Tim
  9. I have an xcal3 will that tell me what error code it is?
  10. OK here is the story, I left for rowing training at 5:30 this morning and the car started fine and took off OK until I got to the end of my driveway were it spluttered a bit but still moved until I got about 200m down the road where it just died with the engine light showing. I popped the bonnet thinking maybe a hose or something had come off but all was good so I just tried turning it off and on again a few times and after about the 4th time it seemed all good and it hasn't missed a bit since. is this anything to worry about and should I go and see if an error code recorded? if you need anymore info to help in answering just ask. Cheers, Tim
  11. Thanks Rap1d, I just had another look through the King Spring catalogue and I found these ones, KFFL-57/520+ KFRL-68SSL/310+ but it says its for the FALCON BA BF GT & GTP/Sports would these ones fit?
  12. Does anyone have the part numbers for the 520 and 310 springs? I have tried finding them but I cant so any help would be much appreciated Cheers, Tim
  13. Cheers for that, ok then I suppose my next question would be on the high boost setting does a T chew heaps more fuel than if it was running on a lower boost setting?
  14. Cheers thanks for that
  15. Ok, can I run a boost controller with a flash tune so I can run the high boost tune and then use the boost controller to limit it down to a more friendly level for everyday driving then just flick it up to high boost when I want to play? would this cause any problems in the ecu like over fueling or anything like that? Cheers and sorry if this is a noob question, Tim
